Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Tavern > The Tavern
The Tavern Kick off your shoes and sit back with your favorite beverage and enjoy talking about whatever you like.
Old 03-03-2008, 04:17 PM
Big Joe Big Joe is offline
Default I would like to know
what kind of speedometer/odometer ya'll have. I have a Worksman PAV. The distance between the fork leg and the spokes is too great for the transmiter and the magnate. This distance is supposed to be 1mm, which is almost touching. I need some type of "bracket" to attach to the fork so the transmiter can attach to the bracket. The old dial type speedometer/odometer will not work because the axle is too large and the front wheel has drum brake. Any suggestions will be appreciated.
Old 03-03-2008, 04:56 PM
Norman's Avatar
Norman Norman is offline
LORD VADER Moderator
Default Re: I would like to know
Would using JB-weld and a plate of metal get you close to where you want to be? Use the quick set JB to glue on a mount for your thing. You can use masking tape to build a dam to put the JB in to build up the area then grind it to shape with a dremel or file/sandpaper etc. Just some ideas for you .
norms-iron-works.tripod.com
Old 03-03-2008, 05:59 PM
paul's Avatar
paul paul is online now
Administrator
or a spacer underneath the transmitter to put it closer then mount with your tie straps. i use a cheap schwinn one and you can angle the pickup on the tube towards the wheel
Old 03-03-2008, 06:50 PM
nogoodnic's Avatar
nogoodnic nogoodnic is offline
For looks I have a cheap mechanical one that sorta works +/- 5mph. If I actually want to know how fast I'm going I zip tie my GPS to the handle bars for an accurate reading. I was alway told that the CDI on our bikes would interfear with the standard bike computer but it sounds like you guys are having success with them...Kelly
I'm racin' Spitfire, turnin', poppin' wheelies, burnin' evil chasin' pop,pop, pop,pop,pop.... (The Pixies-Tony's theme)
Old 03-03-2008, 06:55 PM
paul's Avatar
Administrator
yes the cdi will mess with the electronic cyclometer. to cure this radio shack part number 273-105 which is a snap on ferrite data-line filter cures all problems and i find my cheap speedo is as accurate as my gps and a lot less expensive. the cost of the filter was 5.29 RadioShack.com - Cables, Parts & Connectors: Component parts: Inductive products: Snap-Together Ferrite Choke Core
Old 03-03-2008, 06:57 PM
This cycle computer is a Schwinn (around $10 from Walmart). I emailed Worksman about a bracket. He said they would try to design a bracket. I have some ideas but am limited on equipment and skills. I an gping to try to draw a sketch and send to Worksman. Thanks for your suggestions.
I read the forum several times a day and really enjoy the comments, stories,ideas, builds. and pictures.
Old 03-03-2008, 07:37 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
connect an L braket to the fork with a hose clamp.. sounds good have no idea what im talking about
Old 05-19-2008, 09:39 AM
ran49's Avatar
ran49 ran49 is offline
I started out with a Bell wireless speedo (walmart).It punked out after about 150mi.Upgraded to a Cateye with a wire which worked fine for about 300mi.than got a mind of its own.I'm out $50.00 total and pissed.Not quite broke yet I bought some ferrite filters off Ebay.Turns out The Cateye snaps into a base unit and has 2 small contact points.I polished these points applied a little vaseline and that fixed it.Got 800mi.on it.
To get to my point,I bought a 5 pack of these filters.I don't know if there's anything to this interference theory,but if your convinced you need one send me a PM.Free to first 3 responders.Ron
