Old 10-20-2008, 03:53 PM
Nomad Nomad is offline
Default Lights "kill" engine???
I had my lights running off the white wire and all was well, but recently when I connect the lights while the eng is running it kills the eng immediately. I don't have a "switch" for the lights just a "plug in" when needed. I checked the wires and the bulbs all is ok... this is puzzling, anyone have any input as to what the problem could be?....
thanks.
Bob
Old 10-20-2008, 04:38 PM
jburr36's Avatar
jburr36 jburr36 is offline
Default Re: Lights "kill" engine???
How's the spark plug look?
Anyone who has never made a mistake has never tried anything new. - Albert Einstein
I used to say that politics was the second-oldest profession. I have come to know that it bears a gross similarity to the first. - Ronald Reagan
"You do not want to get between Michelle and a tamale." - Barack Obama
Old 10-20-2008, 04:44 PM
jburr36's Avatar
Maybe the light's resistance is changing with the temperature?
Old 10-20-2008, 04:45 PM
jburr36's Avatar
Perhaps some moisture or dirt causing a short in the plug?
Old 10-20-2008, 04:46 PM
Last time I looked it was a nice dark chocolate brown, the engine runs ok otherwise, it does seem to "miss" when I crack the throttle but it's always done that and I think that's because of the crappy mufflers the kits come with..
Old 10-20-2008, 04:47 PM
I'll check the plug soon as she cools off... thanks for the advice.....
Old 10-20-2008, 04:50 PM
FileStyle's Avatar
try the sparkplug wire! replace with a new 7mm wire. you can get a single wire from your favorite auto parts store. mine would do that also , I would have my bike warmed up good and as soon as I would try the light it instantly killed the motor. I replaced the wire and taa daa it works now.
FileStyleCycles
Old 10-20-2008, 05:50 PM
Plug looks good, I did replace the original plug wire when I built the bike.. But I'll take your advice Filestyle1 and replace the plug wire. I bought a plug wire kit for a 4 cyl chevy which gave me 8 plug connectors and lots of wire. The parts that connect to the coils also connect to the plug... 10 bucks, they wanted 8 dollars for one wire and connector....thanks for the tip;..
Old 10-20-2008, 06:31 PM
New plug wire had no effect, still dies... Maybe I fried the white wire thingy inside, eng runs really good though....
Old 10-20-2008, 07:03 PM
drhofferber drhofferber is offline
is the light 12 or 6 volt...12 will kill the engine...dennis
