I'm nearing completion on my first build and my last step is to fit the drive sprocket and chain but I just found out the the center hole in the sprocket is not a large enough diameter to fit over my coaster brake hub. What are my options? I'd like to retain this rim/hub set because they are the original painted rims that came with my 50's Columbia Rambler and give it a cool vintage look. Does someone make a sprocket with a larger center hole? Thanks for you help...
