Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 10-19-2008, 04:43 PM
ace ace is offline
Default throttle
i have bike set up with a weed whacker it uses a bmx peg. I can't figure out how to put in a throttle help?
Old 10-19-2008, 06:02 PM
comfortableshoes comfortableshoes is offline
Default Re: throttle
run a brake cable to the engine, and somehow attach the brake cable tot eh old throttle cable.
I snipped about 3 inches off the original throttle attached that to my brake cable by winding a length of solid copper wire around both the new and old for about one inch and 1/4 inch thick. Then I soldered the whole thing together.
I have also used electrical wire crimp tube- slide each piece through and crimp the dickens out of it. this worked well at first
And I have also ziptied the cables together..... this actually worked really well until I soldered them together that hasn't budged yet and will be my go to attachment for the future.
Made in china, made better in my garage
Comfortable Shoes Studio Tool Rolls and Pouches
MyMotoredBike.com
Flicker Page
Don't feed the trolls!
Old 10-19-2008, 09:46 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
I just used some jb weld to attach a throttle cable. Made a loop and where the cable folded back on itself I wrapped some black tape the jb welded the to ends of the cable together then did the same with the other piece of cable making a cold weld joint in it as well
probably could just lay the two wires side my side and jb weld them tother but the way i did it the stress was not really on the weld complete
