Old 10-19-2008, 01:55 PM
velardejose's Avatar
velardejose velardejose is offline
Default Cyclocomputer keeps reseting itself
Hi
Just installed a cyclocomputer
Assize brand (I know it is no vdo or cateye unit)
Anyway, when starting the engine it gets mad, flashes all codes and rests itself
I replaced my sparkplug wire (solid copper) with a carbon core piece
Doesnt rest anymore, but sometimes I get too fast readings (99 kph)
Would like to read your opinions
Thanks in advance
Old 10-19-2008, 02:06 PM
jerseykat1's Avatar
jerseykat1 jerseykat1 is offline
Default Re: Cyclocomputer keeps reseting itself
not familiar with that brand. i use the bell 7 function computer i believe, i had the resetting problem until i changed the plug wire. but i never get the too fast error. I would try a diffrent brand.
Old 10-19-2008, 07:49 PM
comfortableshoes comfortableshoes is offline
try a sigma 800, I've had no problems with either sigma (also have the 1200) that I own and they are rated to 50mph by SIGMA but have been tested on the road on street bikes up to 125mph.
When you installed did you run the wire straight do the front fork or did you wrap it around? I've heard that wrapping ti around the fork can help with the interference.
It could be that the speed is what is causing the read error. I had a cheapo $10 unit from target and it would carp out after only 18mph... what a POS. I'm sticking with wired sigma units from now on.
Made in china, made better in my garage
Comfortable Shoes Studio Tool Rolls and Pouches
MyMotoredBike.com
Flicker Page
Don't feed the trolls!
Old 10-19-2008, 09:00 PM
Hi
I know that to have the wire loose is to make an effective antenna
Carbon core wire helped
Maybe a resistor spark plug?
When pedaling the reading is constant
When starting the engine reading can be coherent or sometimes shoot to 99 kph...
I will secure the wire to the fork and try it
If it doesn't work I'll use stereo microphone cable (2 conductors + shield)...
Peace
This MB thing is better (and cheaper) than therapy
Old 10-20-2008, 02:53 AM
jburr36's Avatar
jburr36 jburr36 is offline
My cycle computer can be taken off the handle bar mount exposing the 2 metal contacts. I'm wondering if maybe yours does that then the motor's vibration could be causing breaks in the contacts or in the battery compartment. If not then the interference from the EMF on the spark plug is causing it. One way to find out is to wrap some aluminum foil (copper would be better) around the sensor wire to the computer and ground both ends. The shield would prevent the interference.
Anyone who has never made a mistake has never tried anything new. - Albert Einstein
I used to say that politics was the second-oldest profession. I have come to know that it bears a gross similarity to the first. - Ronald Reagan
"You do not want to get between Michelle and a tamale." - Barack Obama
Old 10-20-2008, 03:03 AM
Goat Herder's Avatar
Gutter Rider
Somtimes if the magnet at the spockes touches the pick up sensor just the tiniest bit the vibration from that confueses the computer. Found that was happing when I got abnormal high readings. Hope that helps. I use the cheap walmart Bell 7
