Closed Thread
Old 10-14-2008, 12:50 AM
Hauzer Hauzer is offline
Default Motor won't start
OK, here's what happened:
After getting the gasoline and motor oil, I poured the motor oil in first then the gas with the gas lever accidentally open. The oil promptly went down the tube and into the carburetor. I realized my mistake after it wouldn't start with that.
So, I drained the fuel out into the gasoline container and poured the rest of the oil in there. I bought 1 gallon, and the oil was 8 ounces.
After shaking it up I poured it back into the gas tank with the lever closed. Then I opened it up and did the usual start procedure (priming and the clutch and all that)
It still wouldn't start.
So I took off the carburetor and loosened it up enough to where it would drain the oil into a pan quickly and easily. I tightened it up and put it back on to tried again.
By now I've attempted getting it to go many many times, and it just won't start up. I used a hill too.
Reading the other threads, I've come to the conclusion that perhaps it's the magneto... or maybe the spark plug. It could also be the carburetor. Or perhaps I permanently broke some component by flooding it with unmixed oil.
The thing is I don't know and I've got midterms to worry about. So right now it sits in my bathroom (after I drained the fuel back into the gas container - which now sits in the outside storage closet). I'm hoping I won't have to order a part, so I'll probably buy a spark plug first. Next I could try replacing the carburetor, then I could try replacing the magneto, or perhaps the black box thing?
And yeah, I tried it without the kill switch
The only thing I know works for certain is the piston. It goes up and down and put-putts if I go fast enough. That's it =p
My bike is more useful without the motor at this point, and I'm wondering if I should have just let it be and not get the kit at all.
The kit was purchased for $250 at Five Flags Motorbikes. It is brand new, and made in China. The size is 70cc and I had to take the filter off the carburetor just to fit it on my bike.
If I'm unsuccessful in getting it to work, I'd happily sell it here to one of you more knowledgeable people at a significant cost reduction.
Old 10-14-2008, 01:30 AM
Egor's Avatar
Egor Egor is offline
Default Re: Motor won't start
I have seen too many of these engine that will not start lately. Well I think you need to find out if there is spark and then go to the fuel. The oil would not hurt anything so that is not a problem. Lay the plug on the head and turn the engine over and confirm there is a spark, you can do this any place just push the wheel with the pedal or move the wheel with your hand should be enough. Make sure the wires from the coil are in the correct order and not touching. If the plug is not firing hold it away from the head 1/8" to see if the plug is bad, you can do this with a rag to balance the plug the 1/8" if you are chicken about getting shocked. LOL. It sounds like the carb is getting fuel these engines need a fair amount of choke and wide open throttle to get them going. Have fun, Dave
Its just a job. (Link) My shop is in the lower R/H corner. http://www.longbeach.gov/about/ABC_webcam.asp
Old 10-14-2008, 03:50 AM
MikeBike's Avatar
MikeBike MikeBike is offline
pm sent
the mag and CDI didnt cost more then $35
Old 10-14-2008, 02:05 PM
It's the magneto!
First I took out the spark plug so that I could see it fire and pushed - no spark.
Then I took out the wires and held the ends in my fingers and pushed - no shock.
Thanks Mikebike for that PM! I will order a new one asap.
Old 10-14-2008, 02:13 PM
MikeBike's Avatar
i hope dax has good quality parts, if not i think we need to take the china engines to honda or rotax and ask them to build there own model but fitts on bicycle
Old 10-14-2008, 07:04 PM
Bikeguy Joe's Avatar
Did you make sure your plug wire is screwed all the way into the cdi?
Old 10-15-2008, 08:16 AM
I sure did! Right now all I can do is wait for the new part.
Old 10-15-2008, 08:14 PM
MikeBike's Avatar
im right there with you.
have to have a new part:
haveing to wait for the new part:
Old 10-15-2008, 08:32 PM
stude13 stude13 is offline
having gasoline in the house is bad.
Old 10-15-2008, 08:40 PM
MikeBike's Avatar
KABOOOM
then youll be mad
Closed Thread
