Old 10-13-2008, 11:31 PM
cartisdm cartisdm is offline
Exclamation Big mistake
I ordered one of those 49cc chinese kits off ebay. I didn't put much thought into the frame size until about ten minutes ago.
My motor will arrive sometime tomorrow but I just looked at the frame size on my mountain bike and it's a 17in. Am I going to run into some serious mounting problems?
Old 10-13-2008, 11:48 PM
LordMaximo LordMaximo is offline
Default Re: Big mistake
It should fit real snugly.............there are ways to adapt any engine to a bike.......maybe a frame from the local thrift store is in need of customizing?
Old 10-13-2008, 11:50 PM
Dave31's Avatar
Dave31 Dave31 is online now
Link...http://motorbicycling.com/f3/what-ki...mmend-510.html
At least 12.5 inches running along the seat tube from the top of the bottom bracket to the bottom of the top tube.Tubing size from 1-1.5inches on the both the seat and down tube. Plus or minus 70deg. above the bottom bracket between the down tube and the seat tube. Inner distance between pedals needs to be greater than 4.5 inches in width to clear the 4.5inch wide motor.
Old 10-14-2008, 12:14 AM
That's good news, if all goes well I'll find out soon enough. I don't mind hitting up home depot and grabbing whatever I need to make a mount, I'm mostly concerned about it fitting in the frame (since I have no idea what to expect seeing as how I've never seen one of these motors before)
Old 10-14-2008, 06:24 AM
skipu's Avatar
skipu skipu is offline
yup but its doable just way more time consuming im on the same page but mines 3/4 built working out some minor clearance situations with carb reed setup
Old 10-14-2008, 09:51 AM
I just did a quick check, I have exactly 12'' along the seat tube from bottom tube to top tube. I'm guessing I'm going to run into problems with the carburetor. Any ideas?
Old 10-14-2008, 11:10 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Wait till it comes before you build it... seriously no sense agonizing just yet...
Old 10-14-2008, 01:57 PM
bravofire84's Avatar
bravofire84 bravofire84 is offline
i ran into a lil problem with my 19inch frame with the chain being to loose so i up grading to a bigger old skool frame like those ppl used to ride on in the tour de france.Yea the ones with skinny wheels.
Old 10-14-2008, 02:04 PM
skipu's Avatar
like deacon said get it then the ideas may arise possibly adapt a 90 to it stick it out the side a littlebit still i would wait you will have a clearer picture PEACE !!!!
Old 10-14-2008, 02:55 PM
Dave31's Avatar
I've got 14" with less then a inch of clearence...I think that will be a very tight fit.
