Greengabbard
I recently ordered a Bumble Bee Bolt On and it came in the mail yesterday. So this morning after I put my kids on the bus I cracked open the box and started installing it on my Raleigh 21 speed road bike. Fifteen minutes later I was done. I was shocked!!! It took me longer to go get gas and mix the oil in with it than it did to put the engine on the bike.
So I mounted up and pedaled off, then I engaged the engine on the rear wheel and it started right up!!! No fuss, no issues at all. It runs like a champ and carries my 250 lb frame around without complaining. I only had to adjust one thing after getting her running; I needed to adjust the tension that holds the friction wheel to the rear tire. After that it was smooth sailing.
After several hours of riding I can tell you that it is very easy to install, very easy to start, very easy to run and very easy to ride. It idles along at about 5 MPH and it's flat ground top speed is 25-27 MPH (on my bike anyway).
I have a question for any of you friction drive folks out there: How far do you generally ride in one trip? Any thought for extending the range (the gas tank is tiny)?
I'll post again soon and let folks know how she is doing.
Thanks for reading,
CGGB
Thanks for reading,
CGGB
