Old 10-13-2008, 03:59 PM
Nomad Nomad is offline
Default Muffler keeps blowin' gaskets.???
My muffler keeps blowing gaskets for some reason, I decided to bash the muffler with a hammer to make clearance from the lower mounting studs ( I know it's not the right way to do it) I will not "Rube Goldberg" any more mufflers or other parts, Modify; yes---- bash with hammers NO... anyway I have cut the muffler off the pipe and installed a shorter muffler (small eng muffler from Ace hdwe) worked ok and acutally made the eng quieter but the exhaust "note" was a little more "piercing"... decided to install the original muffler via copper spacer and there's no tension on the pipe but it blew the gasket after a few minutes, during which time the engine actually ran better .. smoother, more power.. can anyone tell me where to get a muffler/pipe setup that I won't have to "fiddle" with?... I'm gettin' tired of this *&^($#@ muffler issue...
Old 10-13-2008, 06:28 PM
Bikeguy Joe's Avatar
Default Re: Muffler keeps blowin' gaskets.???
You may want to use a file and make sure your flange on the header pipe is nice and flat.
Do the same to the jug after you remove the studs.
Old 10-13-2008, 08:14 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
It could also be clogged up w/ rust or ??? & have too much back pressure...
