| Wheels, Brakes and Suspension Keep your motorized bicycle on the road with suspensions, rims, tires and disk, drum and caliper brakes |
10-12-2008, 12:53 PM
Finding Cruiser Brakes
I have a Micargi Cougar GTS and want to put hand brakes on it. I found the double pull hand brake but, can't find the actual brakes for it. I see brakes on the multi speed cruisers, can't find just the brakes for them that will go over the fender.
Thanks for input!
10-12-2008, 06:14 PM
Re: Finding Cruiser Brakes
I'm not sure what the fenders are like on your bike, but for mine I just added a pair of old side pull brakes. Without the pads on they fit over the fender no problem. If they won't fit I did see pictures from one builder who just used a pair of channel locks to dent in the sides of the fender enough that the brakes would fit. If you can lace a wheel you might also consider a disc or drum brake for the front. Good luck!
-and-
I'm not lost, I'm exploring!
10-12-2008, 06:31 PM
I have a side pull off a BMX but, they don't look long enough to grab the wheel. Maybe it's just an illusion. Maybe I need to know what kind of brakes will fit from other bikes.
10-12-2008, 09:10 PM
Odyssey 1999 Brake/Lever Set For BMX is the set I just bought for an old cruiser. They are the longest reach of a current quality brake but is not as good as a disk, cantelever or v brake set up.
LennyHarp of Lenny's Bikes & Things
http://lennyh.com
The true value of a man is not judged by what he has, but rather by what he can do without.
"We are what we repeatedly do. Excellence, then, is not an action, but a habit." -- Aristotle
10-12-2008, 09:24 PM
if you are not afraid to ruin your paint job (you can repaint it) i would weld on some 10mm x1.25 (not 100% sure on the thread pitch, you should buy the studs that i am about to mention first then match up the nuts) nuts to your frame and fork (provided its a steel frame) install some cantelever studs to the nuts you just welded on(local bike shop sells them) and install some v brakes, IMO sidepull brakes just don't cut it, v brakes or disc brakes work great.
10-12-2008, 09:46 PM
www.BikeParts.com search over 39,000 bike parts
Here are some common steel brazeons if you want to braze or weld them on a steel frame.
NOVA CYCLES"The Framebuilder's Source"
Nova Cycles is another supplier I have gotten frame building parts from.
http://lennyh.com
10-13-2008, 04:26 PM
Tektro apparently has a side pull brake designed for beach style cruisers. It's model A324, if I recall.
I just can't find anywhere on the net to order it, and Tektro doesn't deal with individuals.
Brenton
10-16-2008, 07:35 PM
I found these brakes Cruiser | BikepartsUSA and they are suppost to be for a cruiser.This is the size they gave 1020x35 front & rear. Does this sound like they will fit?
10-16-2008, 08:07 PM
side pull brakes suck IMO unless you can find a good pair of pitbull brakes the really good stuff from back in the day and they are impossible to find only sidepulls left is the cheap ****. if you can weld and paint install v brakes your life kind of depends on it.
10-16-2008, 08:16 PM
My bike is chrome and I can't weld. Does the v brakes put on a greater force?
I found some BMX pitbull brakes. Is that the same thing?
| Thread Tools |
| Display Modes |
Linear Mode
