Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Welcome Forum > Welcome to the World of Motorized Bicycles
Welcome to the World of Motorized Bicycles Forum announcements and instructions for posting on motorbicycling.com. To start a new thread choose the appropriate area. No new threads can be started in this area
Old 06-10-2012, 01:04 PM
biknut's Avatar
biknut biknut is offline
Default Re: Glossary Of Motor Bicycle, bicycle parts and tools
2 stroker = Teenage male in first time sexual encounter.
Old 06-11-2012, 04:57 AM
Old Reliable Old Reliable is offline
Some exhaust terms: back pressure, baffle, volumetric efficiency, exhaust port, header, expansion chamber
Old 06-11-2012, 07:43 AM
Dan's Avatar
Dan Dan is offline
Staff
Great input. Thanks. Is coming along faster then I thought.
The goal is to have the glossary written by the members so with suggestions please put definitions as well. That way it is a group effort and we can edit as needed, as we go along.
worst apocalypse ever
http://www.youtube.com/watch?v=y6Sxv-sUYtM
Old 06-11-2012, 10:16 AM
fonzie fonzie is offline
"Squish Band"- Outer area of cylinder head that forces the unburned fuel/ air mixture into the center chamber for better combustion.
Old 06-11-2012, 11:30 AM
Al.Fisherman's Avatar
Al.Fisherman Al.Fisherman is offline
To make it easy to find what different terms mean or the common name for parts and tools, I thought we could do a community written glossary.
If your inclined, just add what you like with a description and I will add to the original post.
Will help new folks a great deal.
A. Ape Hangers- long handle bars that one reaches up to.
B.
Bucking bar and bearing
C. Chain Tensioner - A device used to adjust the chain tension.
CC = Cubic Centimeters, refers to the displacement of the engine
Compression tester..
CDI.
CVT = Continuously variable transmission. As engine speed increases the gear ration does too. Similar to an automatic transmission.
D.
E.
F.
G.
H. HT (Happy Time) Nick name for 2 stroke engine kit
I.
J.
K.
L.
M.
Magneto (Coil and Magnet)..
Multimeter.. http://www.cozypad.com/wp-content/up...eter_image.gif How to use
N.
O.
P.
Q.
R. Rag Joint - Used to attach the rear drive sprocket to the rear wheel.
S.
T. TDC and BDC = Top Dead Center, Bottom Dead Center. (refers to piston position and timing.)
U.
V.
W.
Woodruff key..A device with a flat top, flat sides, and a semi-circular curved bottom. Woodruff keys are used to assemble components on a shaft by fitting into a matching curved key slot. China girl has 4 keys. http://www.gemplers.com/images/pages/HC240.jpg
X.
Y.
Z.
*1 *2
Looking for HT's parts?
MY PARTS STORE
HT pre instillation tips.
Engine running problems?
HT breakdown Photos
Ron ><)))))*> Calera, Alabama
Old 06-14-2012, 06:59 PM
multipaul multipaul is offline
You can use the pictures if you like..
Piston Assembly (2stroke)
Piston ring gap (2stroke only)
(Picture of a) Woodruff key
Old 06-20-2012, 07:57 PM
Allen_Wrench's Avatar
Allen_Wrench Allen_Wrench is offline
Resident Mad Scientist
Originally Posted by moonerdizzle View Post
monkey wrench, A/F ratio (Air Fuel ratio)
And Allen Wrenches! Don't forget Allen Wrenches.
"There is nothing wrong with wanting a motorbike that is an extension of your personal taste and fashion sense; if you must ride somewhere, I say do it with style!"
Old 06-20-2012, 10:37 PM
I think it'd be a good idea to include the names of bike frame parts too, since we use them in reference to where things are mounted.
Head tube
Top tube
Down tube
Seat tube
Chain stays
Seat stays
Bottom bracket
Rear (and front) dropouts
- other terms may come to mind soon.
Old 06-23-2012, 06:16 AM
Dan's Avatar
Dan Dan is offline
Staff
W. WOT= Wide open throttle.
Wooddruff Key
X.
Y.
Z.
*1 *2
Old 06-23-2012, 12:54 PM
youknouno youknouno is offline
Wink Re: Glossary Of Motor Bicycle, bicycle parts and tools
This thread is super helpful ... a few more definitions would be handy.
MotorBicycling.com
