Old 10-10-2008, 04:46 PM
MikeBike's Avatar
MikeBike MikeBike is offline
Default Need Help Please Wont Start
hi all. i installed my 1st china kit from ebay, and i got it all up and running lastnight about 12:00 and whent for a 10 mile bike ride, did proper brake in, i shut it off a couple of times last night wile rideing to take a rest and started it no problem.
carb settings: 1/2 choke.
so i put it away last night and did not changed the carb settings.
when i tryed to start it this morning it whould not start.
so i check all my settings, carb, wireing, fuel line, spark plug, cluch.
try agin and agin and agin(you know how it go's)
and still know starty. WTF!!
i am so flusterd...
the piston turns, it does the chug-chug sound, i have know idea what it might be rong. help please. i think i need a new CDI any realy good ones?
thank you all
Old 10-10-2008, 05:28 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: Need Help Please Wont Start
Check for a spark... if there is none, it is always the mag-coil in the side of the engine!! (they go bad all the time!)
Old 10-10-2008, 05:47 PM
OSCAR383's Avatar
OSCAR383 OSCAR383 is offline
the first thing that went on me is the intake gasket after my first semi-long ride . if you cant see the gasket material on the top or bottom of the intake its probably blown . and will have to go to the part store and buy a sheet of felpro gasket paper. when the piston goes up and dosn it makes pulses in the intake which alternate from vacume to pressure and the cheap gaskets they come with give way sometimes more offen than none
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 10-10-2008, 07:32 PM
Bikeguy Joe's Avatar
Check for spark.
Check to make sure you have adequate fuel flow to the float bowl. (push the tickler down until fuel flows out of it)
If those two don't do it, take the intake off, and use some RTV or other silicone and seal both sides of the gasket, or what's left of it.
Old 10-10-2008, 10:31 PM
MikeBike's Avatar
so what i am getting here is ether:
1 i am not getting any spark
or
2 i am not getting proper compression (the seal)
so how would i check if i get any spark?
and if i take off the intake tube (going from carb to piston) should i expect any thing flying off like a spring or something like that.
i really appreciate all the help thank you
Old 10-10-2008, 11:47 PM
Motormac Motormac is offline
Try it again with full choke, when it starts to sputter slowly open the choke to 1/2, once its warmed up after running for a minute open the choke to full open (down) position. let me know if this works. Mac
Old 10-10-2008, 11:52 PM
Egor's Avatar
Egor Egor is offline
It is flooded mine has done the same thing a few times. I just hold the throttle wide open and pedal no choke and fuel off. It will start and blubbers till it is clear. No worry some of the petcocks are not good and the carb weeps down the intake and fills the crankcase. Have fun, Dave
PS: You may to have to pedal quite a few feet, keep going.
Its just a job. (Link) My shop is in the lower R/H corner. http://www.longbeach.gov/about/ABC_webcam.asp
Old 10-11-2008, 11:21 AM
or
To check for spark, take out the spark plug & put it back into the wire-boot.
Then spin the rear wheel while holding the spark plug base to the engine head. (make sure the clutch is OFF so that you are spinning engine too!)
The engine will turn over real easy with the plug out.
Either the plug will be making sparks, or it won't...
tell us what you find.
Old 10-11-2008, 11:28 AM
stude13 stude13 is offline
toss the kill switch
Old 10-11-2008, 01:33 PM
MikeBike's Avatar
thanks motormac i tryed that and it was a know go, sorry
thank it was a good thought
