Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 10-07-2008, 05:49 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default butane/propane tanks.
Does anybody know anything about propane torch tanks. I loaned (never to be seen again) torch kit to my son in law. I am trying to find out what the liquid volume of the tank might be. I am considering using one as a gas tank on a bike.
Thanks
Old 10-07-2008, 10:50 PM
Goat Herder's Avatar
Gutter Rider
Default Re: butane/propane tanks.
I hadn't thought about using a prop tank , now I'am thinking
Old 10-08-2008, 05:37 AM
comfortableshoes comfortableshoes is offline
good call d- The look like they are a little larger than a liter, maybe like a liter and a half?, if you compare them to those aluminum or steel water bottles, size wise they are a little larger. It probably wouldn't be too hard to cap that off and tap a hole into it for a petcock or some other barb.... just make sure it's really really empty when you do it, would suck if it exploded while drilling...
Made in china, made better in my garage
Comfortable Shoes Studio Tool Rolls and Pouches
MyMotoredBike.com
Flicker Page
Don't feed the trolls!
Old 10-08-2008, 08:58 AM
deacon's Avatar
"would suck if it exploded while drilling..."
Now there is the biggest understatement of the week lol. My plan was to buy a new one, puncture the seal allow all the gas to escape, then drill two holes for the weed eater lines in the top. Make the cap vented and just use it. I "LOANED" my torch kit to my son in law. (Gone into the black hole that is his world). The bottles are cheap enough at Lowe's. You know like three bucks. They should attach to the seat down rod with a hose clamp.
How is the best way to empty them anybody have a guess. I was thinking just drive a nail down the seal under the cap.
If you were using a quarter inch line (i'm not) I bet you could side it own over the cut off end of a regular valved torch head. Just a guess. The Chainsaws and WW don't need a cutoff.
Old 10-08-2008, 11:30 AM
Bikeguy Joe's Avatar
Danger Danger Will Robinson!!!! They are pretty high pressure, more so than a spray can.
I would advise againts puncturing any part of one PERIOD!
There are a million more suitable way to make a tank than that!!!!!
Old 10-08-2008, 11:33 AM
@ 70 degrees around 125 psi, at a little warmer, they can go to 390 psi.
Old 10-08-2008, 11:34 AM
Why not get an empty or buy a torch tip and use one up then use it as a tank?
Old 10-08-2008, 11:35 AM
Hammer, 1/4" nail, propane tank, deacon...DEACON!?!
Old 10-08-2008, 11:37 AM
Converting A Propane Tank For Compressed Air
Not that they are making gas tanks, but good info.
Old 10-08-2008, 12:04 PM
deacon's Avatar
Ah say it ain't so Joe. I did it and I'm still more or less alive. Here is what I did to survive. First of all I didn't drive the nail into it.
1. Buy the tank from home depot for $2.95
2. Examine it carefully. Under the white cap there is a push pin valve.
3. Very important do NOT use a finishing nail to push it down. At least don't hold it in your finger while you do. The gas comes out a lot like freon. Much colder than a stepmother's kiss.
4. Do put your finishing nail into a pair of vise grips sideways. Keep your hand out of the stream of gas.
5. MAKE SURE IT IS COMPLETELY EMPTY.
6. Drill a 3/8 inch hole into the tank through the main opening.
7. Drill an 11/64 hole down the smaller opening.
8. Use electrical tape to make an X where you want to drill the second hole. Drill it through the tape. It will keep your bit from slipping out of place.
you should be able to attach this to the seat down rod with a hose clamp or two.
Wash and thoroughly dry the tank. Now I have to figure out how to get a fuel filer either inside that very small opening or I have to find or make an inline one.
PS it holds 32oz of liquid. I did have to epoxy a different top on to use a cap. that one didn't fit anything. I just cut the top out of a plastic canteen I had laying about used some stuff to make it fit then epoxied it to the outside of the opening on top.
