Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes, Sprockets and Chains
Hubs, Gearboxes, Sprockets and Chains Can't find 'em, grind em - hubs and transmissions, problems and modifications to make you run smooth and trouble free
Old 05-08-2012, 06:40 PM
RicksRides's Avatar
RicksRides RicksRides is offline
Default 420/428 chain/sprocket question
heres my question I know the 420 and 428 sprockets are interchangable one way. am I right that the difference is only chain width. One of my builds has a 420 sprocket on engine and a 428 on the rear tire do I use the 420 chain or a 428 chain? Anyone??? Thanks Rick.
Old 05-08-2012, 06:45 PM
RicksRides's Avatar
Default Re: 420/428 chain/sprocket question
Tried to use the chart but there are no seperations between everything and Im having a hard time with the chart it just blends together thru my eyes
Old 05-08-2012, 08:32 PM
A 420 and 428 chain are different in every dimension. If you HAVE to mix and match, I'd run the 420 chain. Not sure how it's gonna work though
Old 05-08-2012, 08:35 PM
That was not right, they both have a 1/2" pitch.
Roller diameter is .306" vs. .335"
Between inner plates- 1/4" vs. 5/16"
Pin diameter- .156" vs .177
Old 05-08-2012, 10:13 PM
RicksRides's Avatar
thanks joe I been told i can use a sprocket from a mid 60s cb/cl 160 on the lifan 125 Ill cross reference them tomorrow as well as consulting the micro-fish drawings. I know you can mix n match some chains and sprockets. I just couldnt remember which ones. Thanx again
MotorBicycling.com
