Old 04-29-2012, 02:47 PM
WayneC WayneC is offline
Default Mono-Wheel Cargo Trailer
I posted this in the General Discussion but could also be in the DIY I guess. Mods feel free to move.
I recently finished this trailer for my work bike. It will also transfer to any other bike I have with a rack - pedal or motor. It's fashioned after an Oxtail Trailer ( but cost me a lot less as most of it is re-purposed parts from up in the attic. All I had to buy was some 3//4" EMT and a few nuts and bolts. I also debated various boxes for it and finally settled on a Stanley tool box with wheels and pull-out drag handle. It can be removed easily from the trailer frame and taken to a jobsite. That was $20US from Ace hardware but I figured it could be of use no matter what I decided to do with it.
The trailer has the advantage (without the box) of adding a piece of plywood for a flatbed deck. Or just use the frame and welded eyes to strap anything to it. I can also make a longer or shorter main trunk for it if the need arises to carry longer stuff. As it stands its a long drink of water at 11 ft. from front of bike wheel to rear of trailer wheel.
There is no suspension other than a hinged front pivot between the lower towbar and the main trunk. This connection is cushioned with a rubber fitting that remarkably absorbs quite a bit of shock and allows the trailer to "break" when it encounters a rough patch. I left myself an "out" though for a rear spring if needed -- but I don't think it will. The rear attachment to the fork is bolted together but also hinged. Although it is bolted rigid for now.
Unloaded I have to keep looking back to make sure it's still with me. It handles well loaded too. I've got about 100 miles on it so far and it really travels well. I've had about 25lbs. in it so far and all I notice is the motor isn't as peppy - DUH! The bike will still do 30MPH and climb my biggest bridges on my route with ease, but I normally cruise between 20-25MPH and its a good easy ride.
It was a fun build and something I really needed for my work bike. I got to finally use my HF flux wire welder and was having a blast with that although some of the welds were actually brazed with the O/A torch. So its probably not something someone without a welder could build unless using a LOT of nuts and bolts.
Between all the bike bags and the trailer I can make a day of it and carry everything I need and some I don't.
Old 04-29-2012, 03:59 PM
2door's Avatar
2door 2door is offline
Default Re: Mono-Wheel Cargo Trailer
Very impressive, Wayne. Clean, simple and functional. Sure beats hauling everything in a backpack.
Thanks for sharing with us. I think others will be inspired to copy your idea.
Old 04-29-2012, 06:47 PM
rustycase's Avatar
rustycase rustycase is offline
Gutter Rider
I think it's great that you designed it for a pre-fabbed container.
I have something in the cobweb locker along that line, but of course, cheaper. :-)
My goal is cheap, reliable, personal transport, below the tax collector radar. Fun counts for a lot!
Old 04-29-2012, 07:48 PM
Eight433 Eight433 is offline
I like it! Here is one I built for my motorcycle a couple years ago
and a two wheel trailer for a bicycle I built for my buddy
Old 05-01-2012, 03:39 AM
killercanuck's Avatar
killercanuck killercanuck is offline
That's a great looking hitch WayneC, love the trailer too. As Eight433 has already demonstrated, there's a few of us that like to build our own. (nice trailers too btw Eight)
I've been thinking of a mono-wheel too. It must feel a lot safer being that much more narrower. And of course having the frame adjustable would be a huge bonus. I feel fat with a two wheel out back.
Thanks for sharing man!
I built a two wheeler a while back out of 2x2's and x4's(lol) that ones doubled as a bike hauler, Over here, and a couple of other members shared their trailers towards the end of the thread. (its short)
There's nothing a little creativity can't do eh?
Cards, 29er, Trailer, Hack'em'up
Build with pride! Build to ride!
"A clean shop is a sure sign of a cluttered mind" ~ fasteddy
