| Motorized Bicycle Trouble Shooting Use this area to post problems that may arise that you could use some help in figuring out what is wrong with their bicycle motor and what needs to be done to achieve top performance. |
04-28-2012, 06:01 PM
Gas Tank Leak a mounting bolt
SO i noticed today a tiny leak where the bolt goes into the gas tank for mounting. I originally kreem lined the tank but I must of tightened the nuts too much and the stress of riding created a small seeping leak there where they go into the tank.
So question is do you think I can sand dremel off the paint around the bolt real well, and then just goop it up with jbweld and call it fine? I dont want to re Kreem the tank that was aggravating.
Thanks!
04-28-2012, 06:05 PM
Re: Gas Tank Leak a mounting bolt
I will only say that with todays gasoline, with the additives and alcohols JB doesn't work after a few days.
About the only thing that may last is something like Saf-T-Poxy and I am not sure it will hold either.
Solder it with a soldering iron, not a torch. Maybe someone else can offer up a better solution.
If it ain't broke, and you mess with it long enough, IT WILL BE.
04-28-2012, 06:24 PM
There is a product called SealAll which will work in a pinch but should be considered a temporary repair. It is made to seal gasoline leaks and works, but, it is a glue and it probably won't stand up to the shock and vibration the tank studs are subjected to for long. JB Weld has proven to be almost useless for this repair (as well as many other things). Seal All is available at many auto parts stores.
Either weld/braze the area or order a new tank. And don't over tighten the mounts. Many of us install some kind of resilient material on the cross bar that will absorb some of the vibration. I like to use a product made for setting auto door glass in the tracks. It's called 'window setting tape'. It's a rubberized material that becomes sticky when applied and reduces the need to torque down on the mounts to hold the tank in place. Double sided tape also works well but doesn't absorb much vibration unless it is the type with a padding.
04-28-2012, 06:38 PM
yea yea lesson learned  The new tank I used rubber underneath it and didnt tighten the bolts so much this time.
I have an extra kit because I ordered a kit for just taking apart the motor and messing around so I used that tank. I am using the motor in this spare kit to do all the things like porting and new gaskets etc.
I have a friend who can weld so I will let him have at it. I got 2.00 invested in woody woodpecker stickers on this tank so want to save it if I can
04-28-2012, 09:10 PM
just a note-i tried seal all on a lawn mower tank many years ago,and glued up the jets in the carb.
made a nice mess for me.i have never used it since.
i used a couple old handlebar grips (i cut them off when i did the motor install) slipped them on the bar and tightened the tank until i couldnt rock it anymore.worked slicker than s#!t
04-28-2012, 10:00 PM
I've had success using electrical solder to seal those cracks.
04-28-2012, 10:15 PM
Braze the studs....that is how to make a permanent solution, but not everyone has access to a torch.
04-30-2012, 12:05 AM
I've had no problem with using JB weld. It is gas proof.
04-30-2012, 07:18 PM
I'm with Ron, braze the stud. A friend got a leak on his after the bike fell over, we washed the tank out with water and made the repair. We put gas Mixture in as soon as possible to rinse out the water and prevent flash rust.
Your results may not be the same,Greg
04-30-2012, 07:36 PM
Like I've said before, I never put water in a tank. I kill any gas/vapor with the exhaust from another engine. In my case I use my small generator. Drain as much fuel out as possible. Hook up a hose from one to the other, run till the engine warms up the tank. About 10-20 minutes is all you need.
I've done from these tanks and as large as a 30 gallon. Becomes a permanent fix.
| Thread Tools |
| Display Modes |
Linear Mode
