Old 10-05-2008, 06:48 AM
SgtNorthcutt's Avatar
SgtNorthcutt SgtNorthcutt is offline
Default 6 Volt LED headlamp w/ small 6 volt motorcycle battery
The guy at the autoparts place told me to use a small 6 volt motorcycle battery and run the white wire to it, then run a wire from the battery to the headlamp so the motor would not be using the spark juice to power the light.
I purchased two LEDs from Radio Shack (3.6volts, 20mA, 1100mcd) to use fro this project.
Any thoughts on this?
Motorized Bike Builder
Veterans Advocate
Sgt/USMC (fmr)
OIF 2.2 Combat Injured-Veteran
PK-80 Powerking Limited motor, 26" 7-Speed Schwinn "Point Beach" Cruiser
Top Speed: 31mph (Break-in period)
Veterans Advocate
Sgt/USMC (fmr)
Black Death
PK-80 Powerking Limited motor, 26" single-speed Schwinn Del Mar with rear coaster brakes only (not recommended)
Top Speed: Unknown
Top Speed: 34
Old 10-05-2008, 08:02 AM
Spunout's Avatar
Spunout Spunout is offline
MB Builder Extraordinaire
Default Re: 6 Volt LED headlamp w/ small 6 volt motorcycle battery
yep. try it out and let us know how it goes. sounds feasable. could be the answer.
Originally Posted by Dan View Post
sn0rk.
Originally Posted by Bikeguy Joe View Post
You are one sick man spun, I like that quality in a person.
Old 10-06-2008, 01:24 AM
Hot Dog Piggy Tails's Avatar
Hot Dog Piggy Tails Hot Dog Piggy Tails is offline
get a 4 diode bridge ac to dc converter otherwise youll be sorry! only 3 dollars
Old 03-27-2009, 02:10 PM
MB-Monkey's Avatar
where can i get my hands on one of those?
Ride it like you stole it!
Old 03-27-2009, 06:36 PM
Cabinfever1977's Avatar
use a 18v cordless power tool battery$20 and 1hr quick charger$20
2 car lights hooked together=24volts$12,1 fuse and 1 on/off switch $5
all from walmart
Old 06-22-2009, 12:26 AM
gberry50 gberry50 is offline
Go to radio shack ask for full wave bridge rectifier mine cost 3.39+tax
Run white wire to ac+ spade connector and although not marked run lighting wire
from the other + spade connector
I run two 1 watt niteize leds in headlight and one 1watt niteize in tail light
I'm going to connect a small lead acid 6 v battery in line with the dc tap on rectifier
when mounting rectifier make sure you sand off paint for grounding.
Old 06-22-2009, 12:58 AM
I get my Rectifiers from Radio Shack also. Sorry about the delay. The ground can be ran two wire also so as not to worry about the mounting ground!. and for LED's youll acheive the most power in series 1watters 3 deep (4 volt) or 6 volter's parallel.
I was quite blown away when I plugged my first rectifier IC into a 1 watt diode and blew it immediately. one in series then two in parallel works good all 6 volt one watters.
Old 06-22-2009, 01:11 AM
all from walmart
Oh Cabin fever Ooh that name gives me the willies'
series you mean. power to + out it's -.. to + of second light out of its negative back to the batteries - terminal. resistive load can handle higher voltage than rated for each bulb x2
Old 06-22-2009, 03:54 PM
I would like to try a 3watt led in headlight but I have learned on this forum that the output of lighting coil is only 3 watts is this true?
Old 06-22-2009, 05:43 PM
6 volt ,3watts ,0.5amps
