Old 04-21-2012, 11:16 PM
ibmeruu ibmeruu is offline
Default Fat Tire Beer Bike, 1st build
Hi My name is David, This is my first build.
I need advice on a rear hub with drum brakes because I broke the stock hub trying to put the crank on it.
Also I want to put a springer front end with disc brakes, but don't know about the basket and fenders clearance.
I was thinking about the shifter kit to avoid running two chains.
Im installing a 70cc motor on it.
I'd like to put a keg tank behind the seat also.
Finally a glass of been on the basket filled with resin and glue to look as realistic as possible would be awsome!
Thank you all for your posts and input you may have the build.
Old 04-22-2012, 08:50 PM
robbomberbomyea's Avatar
robbomberbomyea robbomberbomyea is offline
Default Re: Fat Tire Beer Bike, 1st build
welcome david,im not sure on shifter or drum breaks,but im sure sombody here will have you a answer.good luck,great looking bike.
