Go Back   Motorized Bicycle Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes, Sprockets and Chains
Hubs, Gearboxes, Sprockets and Chains Can't find 'em, grind em - hubs and transmissions, problems and modifications to make you run smooth and trouble free
Old 03-22-2012, 08:44 PM
tjmortenson tjmortenson is offline
Default How can I put a #35 chain size sprocket on a bicycle wheel?
I'm trying to put the motor I took off my minibike on a bicycle. It is a 2.8hp Lifan 97cc from a doodlebug minibike, and I need to figure out how to get a 35 sprocket on my bike wheel. From what I have read, the clamp on ones that come with engine kits are regular bike size chain so they would be too small, but correct me if I'm wrong. any ideas for a sprocket?
Thanks!
Old 03-22-2012, 11:21 PM
Thud Thud is offline
Default Re: How can I put a #35 chain size sprocket on a bicycle wheel?
Hi,
What you are proposing is a fairly simple set up. #35 kart sprockets are cheap & durable (its all i use) & the geometry to layout a 6 hole pattern for the sprockets 5.25" bolt pattern & a 44mm bolt pattern for a disc brake hub is the same. I also have worked on mounting sprockets to a freewheel on the right side.
if you cant afford a new hub or the idea of building your own wheel seems too much. I can show you how to adapt a kart sprocket to a typical "rag" joint adapter.
here is a source for #35 sprockets:
http://stores.ebay.com/MM-Racing-Kar...=p4634.c0.m322
A man with tool's can have anything he can imagine...dream BIG.
Old 03-23-2012, 11:48 PM
Ok, I think I might try to make my own rag joint adaptor. Would a 60 tooth sprocket be good for speed and power? My choices are pretty much 35 tooth or 60 tooth. I don't need a lot of speed, 25-30 mph is plenty, but I would like it to have some acceleration. The minibike it came off had a 70 tooth sprocket, so I should get a little more speed with a slightly smaller sprocket with the same clutch, correct?
Old 03-24-2012, 07:24 AM
It's not really the number of teeth, but the reduction via the number of teeth on the drive sprocket vs. the driven sprocket. The number of teeth will vary with chain size for any given diameter.
Old 03-24-2012, 07:33 PM
Ibedayank's Avatar
Ibedayank Ibedayank is offline
now is a good time to learn about gear ratios
use a gear ratio calculator program and find out what your gearing ratio is
you want between 12-14 to 1 final ratio
use to small of gear your clutch will never lock up and it will burn up to big of gears and you will go very slow at wot
to get useable gearing your going to have to build a jackshaft or run a CVT
Live life as its your last day... it just may be
Learn to do it right or how to fix it later, quicker to do it right the first time.
MotorBicycling.com
