Originally Posted by 4wdingman
Hi
I have a stingray and i want to mount a 48cc motor to it but my problem is that the bolts on the back sprocket get in the way of the metal thing that holds the spocks in??
Can someone tell me how to mount the sprocket...
MOST STINGRAY WHEELS ARE 28 SPOKE RIMS SO YOU HAVE TWO OPTIONS.
1 . YOU CAN SPEND FOUR HOURS ( LIKE I DID) AND FORCE THE BOLTS THRU WITH HELP OF A FRIEND AND IN THE END YOU CAN ONLY GET 8 OUT OF THE 9 BOLTS THRU.
2. OR TWO ( LIKE I EVENTUALY DID) GO TO THE LOCAL BIKE STORE AND BUY TWO 32 OR 36 SPOKE RIMS AND SPROCKET WILL BOLT RIGHT ON IN LESS THEN OHHH LETS SAYS 7 MINUTES.
MY BIKE WITH 32 SPOKE RIMS
HOPE THIS HELPS.
P.S. I HAVE SEEN SEVERAL STINGRAYS WITH STOCK WHEEL WITH ONLY 8 BOLTS IN THEM . IF YOU GO THIS ROUTE MAKE SURE THE HOLE WITH NO BOLT IS IN THE CENTER OF THE THREE HOLE METAL STRIP
THE LAZY RAY WITH 28 SPOKE RIMS
AND IF ITS A COASTER BRAKE YOU WILL HAVE TO EITHER BEND THE BRAKE ARM ON THE LEFT SIDE TO CLEAR THE BOLTS . OR DRILL SPROCKET SOME AND BUT SOME TAPERED BOLTS THAT WILL MAKE THEM FIT FLUSH AGAINST THE SPROCKET .
LET ME KNOW IF YOU HAVE ANY OTHER PROBLEMS .
