Old 09-27-2008, 07:32 PM
joeblow's Avatar
joeblow joeblow is offline
Default need chain info
Hi
I got a an 80cc kit from powerkingshop (an ebay shop) and the site says it is a "standard bike chain" which is clearly untrue. It broke my chain tool. It has a 1/2" pitch and a 5/16" width, which I guess makes it a 428 or a #41 by what research on the internet I have done tonight. Frankly I don't know what it is and I would like to know what kind of chain tool I should use to pop links off.
Old 09-27-2008, 07:59 PM
Ilikeabikea's Avatar
Default Re: need chain info
Hey Joey, welcome to the forum. Here's all the info you will ever need on motorized bicycle chains. http://motorbicycling.com/f30/415-ch...cycle-798.html We're glad you joined us....................
Old 09-27-2008, 08:16 PM
Finfan's Avatar
Finfan Finfan is offline
I ended up going to a motorcycle shop and dropping $30 for a chain breaker. An annoying expense but now I have the tool.
-and-
I'm not lost, I'm exploring!
Old 05-09-2009, 09:27 AM
joeblow's Avatar
I found a nice chain breaker for not much money.
Old 05-09-2009, 09:17 PM
Cabinfever1977's Avatar
i use a jigsaw to cut links and pliers to pull off cut links,its easy,pin falls out,then you put in master link after you removed the ones you want.no special tools required,.
jigsaw from walmart = $15 ,not having to buy a chain breaker tool = priceless
Old 05-09-2009, 09:24 PM
NunyaBidness's Avatar
NunyaBidness NunyaBidness is offline
I've not had much luck with master links. I usually use a chain break tool to push a pin almost all the way out, remove the proper amount of links, then press the pin back in place.
Old 05-09-2009, 09:30 PM
well my kit came with 2 master links,it was easy to use plus i have a spare.
Old 05-10-2009, 02:16 PM
joeblow's Avatar
I would rather use the original pin and keep the chain whole, unfortunately the chain tool I have bends the outside links pretty badly.
https://web34.secure-secure.co.uk/ht...%20Breaker.jpg
it looks like this. Is this a bad chain br eaker? am I using it wrong?
