Muffler End Cap Fix
California
I tried a lot of different muffler end cap fixes, and in the end they all kept falling off one way or another.
I jb welded a soda can to the end and then put a screw threw that, and the screw loosened and it eventually fell off,
then i went to using a washer with some drilled holes in it like some people had done, this worked for a while but eventually the screw loosened and the washer fell off.
i couldn't figure out what was happening, after trying a few different screws in the existing hole i realized that the threading had worn thin.
so i was like F**K screws,
1.Bought one metal pipe fitting from my local auto parts store, they have it with all the other muffler stuff. $2-$4
2.used some QUIKsteel i had at the house.
3.sanded and fit them together.
4. used vice grip to bend to desired width (tried a few)
the pipe used to not be closed and had a cat food can with holes inside (this would work if you used a washer), but that melted away, so i closed off the end. its very secure and runs great,
slightly louder than stock end cap, but i need the little extra boost for going up hills (200 pound rider)
cvlt1
I know not everyone has access to a welder... but throwing a couple of small tack welds on it will keep that end cap on forever! ;)
