Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 09-24-2008, 07:49 PM
HEADDS HEADDS is offline
Default what to stick in square hole?
I found a homelite wacker in my garage, still workin on gettin it running but cut to the chase, I have a shaft with a square hole, what do other homelite users to to their square holes?
Old 09-24-2008, 09:03 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default Re: what to stick in square hole?
Is the square hole on a centrifugal clutch or on a adapter...
Old 09-25-2008, 04:45 AM
comfortableshoes comfortableshoes is offline
no clutch on the smaller homelites... you can get that off with a long socket and then you can do some stuff with it.
Made in china, made better in my garage
Comfortable Shoes Studio Tool Rolls and Pouches
MyMotoredBike.com
Flicker Page
Don't feed the trolls!
Old 09-25-2008, 06:57 AM
deacon's Avatar
Take the spark plug out shove a rope in the plug hole to temp freeze the piston. leave some of the rope sticking out so that you cant remove it after you are finished.
Old 09-25-2008, 06:07 PM
SpiderSpartan SpiderSpartan is offline
some of the really old homelites you can't take the square adapter off. If it's not an antique though you should be able to take it off. Check out the site in my signature to see what I did after that.
PS. Welcome to the forum.
Old 10-19-2008, 10:35 PM
trackfodder trackfodder is offline
I would think some keystock with the other end potted into a shaft with silversolder and stabilized with a bearing plate mounted to the motor would work for you.. Maybe you could cheap off and pot it in JB Weld and put a couple holes in the shaft to keep it from spinning.
Old 10-20-2008, 09:48 AM
deacon's Avatar
everytime I see this thread I want to say well not the round peg for sure.... There i did it
Old 10-20-2008, 10:09 AM
rkbonds's Avatar
rkbonds rkbonds is offline
I tried several different things and they all kept breaking off. I ended up drilling out the hole and using a grade 8 bolt and have had no problems since.
