Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Heads and Cylinders
Heads and Cylinders All about your porting, compression, rings, cylinder and piston modifications to your bicycle engine
Old 01-22-2012, 07:59 AM
allen standley's Avatar
allen standley allen standley is offline
Angry Replacement cylinder Jug
OK Grubee GT5. blew out the wrist pin,bearing. Needed cylinder, Piston, retainers, and all gaskets. Head o.k. Bought all replacement parts from Kings where the engine was origionally purchased in april 2011. Now --The carb manifold will not bolt up to the engine due to the fact the replacement cylinder on the input side (carb Side) is cut to accomodate a muffler. Yeah it's true! How can a screw up like that happen? Anyway I was fortunate enough to have a muffler to cut the flange off, now I must take off the alum. manifold and replace it with the old style steel one with the muffler flange welded on to it. Also the actual wrist pin was too long by about an 8th of an inch. So grinding the wrist pin shorter to fit was not a big problem. Has anyone experienced this situation before?
Old 01-22-2012, 08:23 AM
Al.Fisherman's Avatar
Al.Fisherman Al.Fisherman is offline
Default Re: Replacement cylinder Jug
I have never even seen a post of this problem since I've joined this or any other bike forum. So you are saying that both the intake and exhaust stud holes have the same measurement?
Looking for HT's parts?
MY PARTS STORE
HT pre instillation tips.
Engine running problems?
Ron ><)))))*> Calera, Alabama
Old 01-22-2012, 08:43 AM
Greg58's Avatar
Greg58 Greg58 is offline
Hey Allen I found on the grubee site that the "G" style rist pin clips were the cause of some engine failures. These have now been replaced with the standard "U" shaped style. As for the large intake port I have heard of new engines having larger ports, if you could find a intake that was that size it would perform better.
Grubee Inc.
Your results may not be the same,Greg
Old 01-22-2012, 11:02 AM
biknut's Avatar
biknut biknut is offline
Sounds like you got a cylinder with 40mm spacing on the intake studs. Most have 30mm spacing. Manic Mechanic makes a 40mm manifold.
