Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Hubs, Gearboxes and Sprockets
Hubs, Gearboxes and Sprockets Can't find 'em, grind em - hubs and transmissions, problems and modifications to make your motorized bicycle run smooth and trouble free
Old 01-22-2012, 05:50 AM
bubba bubba is offline
Question Why not?
There's a pretty large market for motorised bicycles.
Why doesn't someone make an internally geared coasting hub for the left hand side of the bicycle, making jackshafts inferior? It almost seems too easy... like a bicycle hub but with a conventional sprocket on the right for pedaling, and a disk-brake style adapter on the left (so you could use any kit sprocket) attached to an internal gearing system?
Old 01-26-2012, 06:59 AM
trug trug is offline
Default Re: Why not?
I'm afraid the market is not that large.
Old 01-28-2012, 04:07 PM
driftology driftology is offline
you can run a sturmey s3x fixie hub backwards
Old 01-29-2012, 06:19 AM
is there some documentation on this?
Old 01-29-2012, 10:42 AM
Its a fixed 3 speed hub. i can pedal backwards in all 3 gears on my bike.
Old 01-29-2012, 09:29 PM
So, you just flip the hub over, so the 3 speed is on the left, and then what do you use to pedal?
Old 01-30-2012, 10:29 AM
On my bike i have it set up on the right with a shifter kit. just making note that it works in either derection. im using it so that i dont have the jam on the pedals to start. the only thing im not sure about is the durability. i ran the sturmey drum 3 speed on the same bike with no issues. i hope this will be better since it doesnt use pawls.
Old 01-30-2012, 10:31 AM
Oh and a side note. the driver side is splined so it should be pretty easy to make a large cog for it.
Tags
gear internal hub
