Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Intake & Exhaust
Intake & Exhaust The ins and outs - carburetors, manifolds, mufflers, expansion chambers and more to keep your motorized bicycle running the way you like
Old 01-18-2012, 04:26 PM
frozenveinz's Avatar
frozenveinz frozenveinz is offline
Default Exhaust sound
Is there any way to make a two stroke have an exhaust that doesn't sound like the offspring of a chainsaw and a hive of bumblebees? Maybe like, put put put? Not YEAANNNN YEAANNNN YEAANNNN?
Jus Keep Cruisin!
Member of the 20 MPH Club
Old 01-18-2012, 04:34 PM
2door's Avatar
2door 2door is offline
Default Re: Exhaust sound
Not much. The laws of physics will only let you do just so much to change the sound of a single cylinder 2 stroke engine. Expansion chambers, megaphones, even motorcycle type mufflers are still going to have that characteristic sound. A longer pipe will soften the crack and ring-a-ding noise but because of the inherent high RPMs you'll still know it's a 2 stroker.
Old 01-18-2012, 04:44 PM
I see. But does that mean a two stroke at 5k rpm sounds like a four at 10k? Or does the valved exhaust of a four produce a different sound?
Jus Keep Cruisin!
Old 01-18-2012, 04:59 PM
2door's Avatar
That's probably not a bad comparison except 10K for a normal 4 stroke would be really pushing it.
The fact that you have twice the number of compression/power strokes with a 2 cycle verses a 4 explains the sound difference. Your 5K to 10K concept is valid.
There is a difference in the restrictions of the exhaust path with valves (4 stroke) as opposed to an open exhaust port (2 stroke) and it undoubtedly accounts for some difference in the noise they make.
