Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Wheels, Brakes and Suspension
Wheels, Brakes and Suspension Keep your motorized bicycle on the road with suspensions, rims, tires and disk, drum and caliper brakes
Old 01-15-2012, 08:07 PM
stretchintha420 stretchintha420 is offline
Default center lock hubs?
has anyone tried using a centerlock disc hub to run a disc brake. from what i see i should be able to ragmount my 34t sproctet to the wheel and then mount the disc. but i cant be the first one to think of this, and i cant find any posts on it.
any thoughts?
Old 01-16-2012, 02:58 PM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Default Re: center lock hubs?
I've used Shimano Alfine 8-speed rear hubs with the center lock disc brake with great results... But those bikes had SBP shifter kits, so there wasn't a sprocket on the disc side.
Old 01-18-2012, 03:01 PM
thanks for the info. my biggest concern was that the lock ring would vibrate off. im pretty sure everything else will work out.
i am currently rebuilding my bike, and really need 2 discs but cant afford to buy a tophat adapter to have it not work. by my calculation this will give me more room. ill just have to use a rag mount.
Old 01-18-2012, 05:46 PM
The_Aleman's Avatar
The_Aleman The_Aleman is offline
"OM NOM NOM"
I've seen centerlock-to-6-bolt adapters on Problem Solvers. Amazon carries them, too.
Amazon.com: Disc Brake Center Lock Adapter SH-2 - Attach 6 bolt rotors to Centerlock hubs: Sports & Outdoors
Problem Solvers
Proud member of The 20MPH Club.
You live more on a bicycle in 1 mile than you do in a car in 100.
