Old 09-22-2008, 08:52 PM
flipkick7 flipkick7 is offline
Question how to hook up kiil switch
i have 2 wires coming from kill switch and bike runs fine without them connected.
i attached blue from magneto blue from cdi and a wire from kill,
and
black from both cdi and magneto with the other from kill
what is the right way to do it without using the white wire
Old 09-22-2008, 09:48 PM
old motorbike's Avatar
old motorbike old motorbike is offline
Default Re: how to hook up kiil switch
I hooked one wire from the kill to the blue-green and the other to ground.
Seems to work good.
Old 09-23-2008, 07:26 AM
Bikeguy Joe's Avatar
The white wire is for lighting only.
Old 09-23-2008, 08:45 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Make sure there is no bare wire at the end of the white wire though it will also ground out the engine if it touches the frame
Old 09-23-2008, 11:51 AM
Dave31's Avatar
Dave31 Dave31 is offline
If you register at Spook Tooth, you can watch his video of hooking up the kill switch
link.........Spooky Tooth Cycles - Motorized Bicycles: Gas Powered and Electric Bikes - VIDEO: Kill Switch Wiring
Old 09-24-2008, 01:56 AM
4wdingman's Avatar
4wdingman 4wdingman is offline
connect one kill switch wire to one the the wires coming out of the motor and the other kill switch wire to the other wire from the motor.
good luck
