Old 09-22-2008, 11:00 AM
Kraash Kraash is offline
Default motor wont fit .. help =(
i just got my 'thatsdax' motor in the mail and the 2 front bolts are to close togeather to go around the slightly fat front lower tube... any idea? =\
Old 09-22-2008, 12:25 PM
jburr36's Avatar
jburr36 jburr36 is offline
Default Re: motor wont fit .. help =(
Ask Dax for the Big tube frame adapter or you can craft your own. I had the same issue and it was a simple fix.
OSCAR383's Avatar
OSCAR383 OSCAR383 is offline
THERES AN ADAPTER PLATE . IT WILL BE RECTANGULAR AND HAVE THREE HOLES USE PLIERS TO REMOVE STUDS AND BOLT PLATE IN WITH THE LONG BOLT POINTING OUT THE OTHER WAY. DRILL A HOLE IN THE LOWER TUBE PUT LONG BOLT THRU AND USE LOCKING NUT ON BOLT END THAT STICKS THRU THE BOTTOM OF FRAME.
OR IF YOU HAVE TIME TO MAKE IT LOOK NICE TAKE A ROUND PUNCH AND A HAMMER . MARK WHERE YOUR BOLTS WILL BE . AND MAKE A TRENCH ON EACH SIDE OF TUBE UNTIL ENGINE STUDS WILL CLEAR.
HOPE THIS HELPS
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 09-22-2008, 01:28 PM
Dave31's Avatar
Dave31 Dave31 is offline
http://motorbicycling.com/f6/oversiz...olved-171.html
http://motorbicycling.com/f6/modify-...frame-660.html
Old 09-22-2008, 01:36 PM
Saddletramp1200's Avatar
Saddletramp1200 Saddletramp1200 is offline
Custom MB Buiilder
You Da' MAN! Solved my issue with the point beach build! U clamps ROCK Now for that electric start
Only Bikers know why dogs love to stick their heads out of car windows,
