Old 09-21-2008, 08:41 PM
Finfan's Avatar
Finfan Finfan is offline
Default So near yet so far.
All right I have almost everything installed now except the muffler. The combined problem is that the muffler when installed will be right up against the motor mounts and that pipe is a lot stronger than it looks. I can't seem to find a way to apply enough leverage to bend the sucker a couple of degrees. I am open to suggestions!
One more thing: 6 HOUR INSTALL MY FUZZY BUTT!!!!!!!!!
-and-
I'm not lost, I'm exploring!
Old 09-21-2008, 09:31 PM
Dan's Avatar
Dan Dan is offline
Default Re: So near yet so far.
Hi finfan. Lots of folks know how to better then I how to do it. As a last resort, a muffler shop would be glad to help ya. I find they love MBs and the whole shop stops working to check out your bike.
Mine was just a wee bit off and the peddle was just barely touching it. I kicked it, snork. Not that I am suggesting that. I have used a rubber mallet successfully as well for small "adjustments" Be sure to use joint compound.
"One more thing: 6 HOUR INSTALL MY FUZZY BUTT!!!!!!!!!" LOL 80ccs, gets 250 MPG and the check is in the mail.
Looking forward to your pics.
I want 2 ride my bicycle
Old 09-21-2008, 10:00 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
My six hour install took a week and i am retired and had all day everyday to work on it. Even then I got it wrong.
Old 09-21-2008, 10:58 PM
Dave31's Avatar
Dave31 Dave31 is offline
http://motorbicycling.com/f4/bending...haust-997.html
http://motorbicycling.com/f3/pedal-n...aust-1305.html
Old 09-22-2008, 01:11 AM
Venice Motor Bikes's Avatar
Custom Builder / Dealer
Put a piece of re-bar or something in the end & stand on the other & BEND IT !!! (you only need to bend it a little!) I've done it before.
The easiest solution is usually the best!!!
Old 09-22-2008, 02:00 AM
Dan's Avatar
Dan Dan is offline
Ayup. when I started on this road of strange addiction, I handled the engine with kit gloves. Now I am not above kicking and hammering. The China girls are pretty amazing things. If you normally run them at cruising speed and not WOT they last and live a good long life. They are tuff lil motors and do more then they should. VB is right. Whats the worst that can happen?
Cool thing I learned a while ago, if you run the exhaust threw a radiator hose, it sounds like a much larger engine with a thumping sound. Might be flammable though. But I have never had a muffler catch fire. Sound is really cool.
Old 09-22-2008, 08:09 AM
Merlin Merlin is offline
FWIW my install actually did take about 6 hours. . .
... but then, that's not counting the fact that it just plain would not fit in the first frame, so I had to go and buy another bike...
[anyone want to buy a Kmart bike? ridden less than 1KM?]
Old 09-22-2008, 09:43 PM
macimpala macimpala is offline
Working at a pattern shop I have access to many things. When I needed that extra clearance for the exhaust pipe I got fancy and made an alum block to bolt up to the flange, put that In the Vise and attacked it with the torch ...Bent like a
charm
