Old 09-21-2008, 10:33 AM
vrod vrod is offline
Default new engine no spark at low rpm
Need help have new engine won't run . turn engine over with drill on sprocket and with spark plug laying on motor have no spark until spinning at hi rpm ????
Old 09-22-2008, 07:24 PM
h0tr0d's Avatar
h0tr0d h0tr0d is offline
Default Re: new engine no spark at low rpm
What are you thinking is "high rpm" ? IF the normal idle is at about 1000 rpm - then that is 16 rotations a second, and only 4 per second on the output after the gear reduction.
Try putting it on the bike and pedal starting it. I'm sure it will start up. It is going on a bike right?
Old 09-22-2008, 07:35 PM
Saddletramp1200's Avatar
Saddletramp1200 Saddletramp1200 is offline
Custom MB Buiilder
Welcome VROD & hOtrOd to the forum Check your cdi ground and lead wire. Or U got a bad spark plug
Only Bikers know why dogs love to stick their heads out of car windows,
