Go Back   Motorized Bicycle: Engine Kit Forum > Motorized Bicycle Mechanical Components > Lighting and Electrical
Lighting and Electrical Things that go ZOT! Ignition components, batteries, lighting and accessories for your motorized bicycle
Old 09-20-2008, 06:38 PM
Jesuswon1 Jesuswon1 is offline
Default ...more than a head light??
Hey gang...
I've searched postings for about an hour, and can't seem to find any ideas for a full lighting system... Before the flames start flying, I'm already aware that the "white wire" from the engine will barely supply enough power to a head lamp, let alone tail lights or signal lights. What I'm wondering about is if anyone has done a custom intigrated signal light system for their custom built "motorbicycle"... What lamps did you use, and how did you mount them? battery? switches, and mounting? Are there any threads discussing this?
I'm riding an old schwinn with a 49cc-70cc (don't really care about true or exact measurements) BGF motor and I'm heading into the winter months looking for a project. I figure if I can't ride it, then I'll continue to customize it.
I'm considering a rear rack and maybe mounting a light cluster at the back of that, and hiding battery and other blinker modules in some custom panier bags.
Thoughts?...Ideas...?
Old 09-20-2008, 10:43 PM
Finfan's Avatar
Finfan Finfan is offline
Default Re: ...more than a head light??
I haven't even gotten my bike running yet, but I have been considering using a rechargeable sealed lead acid (SLA) battery. My thought was to invent a lockable "trunk" mounted to a rear rack to store the battery then just recharge it at home. It just seems like using the white wire is going to be too much trouble. :/
-and-
I'm not lost, I'm exploring!
Old 09-21-2008, 01:22 AM
timoc timoc is offline
why not the old generator set properly installed ,work pretty good
Old 09-21-2008, 07:52 AM
Biker Mike's Avatar
Biker Mike Biker Mike is offline
I've been toying with the idea of driving the old generator with a speedometer cable. Mount it in a small round container below the headlight and run all cables and wires to it there. Just an idea at this point...
Old 09-21-2008, 08:56 AM
ran49's Avatar
ran49 ran49 is offline
More than you'll ever need to know on this site Bicycle Lighting Systems Ron.
Old 09-21-2008, 09:15 AM
Bikeguy Joe's Avatar
Long winter ahead? Go to radio shat and buy up everything you'll need to make your own.
