Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 12-16-2011, 04:37 PM
leaded50's Avatar
leaded50 leaded50 is offline
Default Chainsaw in frame build
When building a Cruiser/boardtracker styled bike, i did it at an vintage (-54) cycle. Because then i could also use it with an motor, claimed by national laws here in Norway.
But to find the old cycle engines arn´t easy here, and the few are pricy, or owners dont wanna sell. Then ist only the lawnmower /chainsaw/weed whacker motors.
For me, and my purpose, a chainsaw engine is small enough..(approx 50cc) got one for free...
Moods: Because my original crank arn´t wide style, just original 110mm, the width is crucial, to not interfere with the pedals. The hole crank &pedals ar made in one unit, lightly to get ruined when trying to widen it.
Old 12-16-2011, 04:47 PM
leaded50's Avatar
Default Re: Chainsaw in frame build
My choice of motor is a Jonsred Turbo Chainsaw (even if i didnt found a turbo....it was just some "pipe" from the fan leading air to get cleaner airfilter...)
53cc, and 3,6 hp at 12500...
Cutted away the tanks (oil/gas) of the crankcase, who is made as one unit.
Cutted straight down making a lip in front & rear to bolt up the motor. Kept the part of front housing for fastning of the magnetic coil.
Also the fanblades on crankwheel did go,together with the pull start. This because interference with pedal width. This could be better when mounting the engine even more higher, and more slanted....but wanted the slant to follow the front tube....and had no space to go higher because the tank...
Old 12-16-2011, 04:53 PM
leaded50's Avatar
Motorblock finished cutting.....BUT, did one fault....cutted the coilpart away, and had a **** of trouble to fasten this again...(found another crankcase...)
If not cutted away, you keep the ignition right on, just to adjust the space against the crankwheel, if needed!
Finished cutting (with coilpart away too...
Old 12-16-2011, 05:08 PM
leaded50's Avatar
Motor mount is made of a rigid thick stainless steel plate, in different angle to let the motor follow the leaning of front tube. (seen on first pic in this thread)
Holes drilled to bolt motor to the edges at front and rear which was kept when cutting the crankcase. Also the forur original bolts to hold the top of the crankcase are longer and goes trough the mount.
Gear ratio: Troublesome........chainsaw motor dont have any reduction gear as a normal motor at use for mopeds, etc.., It will spin at full throttle approx. 12500 rpm! If direct connected, speeds of over 100mph could be shown...IF THE MOTOR COULD GIVE ENOUGH POWER!
Reduction is needed! Made up a jackshaft (axle & bearings w/holders) to get some....
here you also could se the coil housing part is on the crankcase, and the crankwheel have lost the fanblades for more clearence.
Old 12-16-2011, 05:13 PM
NormO's Avatar
NormO NormO is offline
"Turbo" doesn't really mean it's turbo charged. Yes it is just a pipe to inject air into the air filter to keep it cleaner. It is supposed to help raise the HP some as well, and does by .1HP. Non turbo saws are normally 3HP. Still a nifty idea though to use the flywheel to help keep the air filter cleaner. I wouldn't have removed the shrouds though. You may run into overheating problems down the road. I'm curious about how you'll start it without the pullstart assembly though. Looks like you are off to a good start, keep posting progress please.
P.S. It must be an older saw than mine. I have a CS2152 Turbo that i'm using. 52cc 3.3HP @ 13,500.
Old 12-16-2011, 05:22 PM
leaded50's Avatar
Right side. Engine mount is clamped against the front tube & seatpost tube, as low as wanted to clear the chainguard.
Original saw carb are used, just removed filter to change to another later...and made up a stainless steel exhaust pipe, following the angle of front tube.
centrifugal original clutch is still used. This can later be changed to a Go-kart/- type (72mm) if needed, just to cut away the lip around the clutchbell at housing.
I choosd to use a belt drive from the motor to the jackshaft, then it would be easy to change to adjustable tensioner for clutch, and direct sprocket on motorshaft if the clutch wont hold up.
A 7,5" pulley wheel from a washing machine is mounted on the right side jackshaft, and a 1.5" pulley is to be mounted on the clutchbell.
Old 12-16-2011, 05:26 PM
happyvalley happyvalley is offline
I love DIY projects like this, the real heart and soul of motorized bicycles. Look forward toward your progress and best of luck with it!
Old 12-16-2011, 05:29 PM
leaded50's Avatar
Found out the case about the "Turbo"..but had some fun with the seller when he sold a new saw to my saws earlyer owner.. he,he.
Fan shrouds....A chainsaw is kept quite still without air coming into it, just from passing slow wind. A Motorbike is aircooled by the airstream at speed, and the chainsaw motor should get the same treatment? Airspeed cooling it!
I belive it would go...and if not, i get another engine! I dont wanna have a fanshroud hiding a bike engine.
Starting......... Got some ideas, and need to test them first... The standard pullstart interfere with the pedals so it had to go.....
Old 12-16-2011, 05:37 PM
leaded50's Avatar
Thanks!! I hope i dont need to trust only at luck....but that some skills could help too! :-)
One idea of mine is also to not just buy finished, but having the fun of using whats can be used, if needed modify, and all without big costs. Not everyone have the cash to do it, an i be happy to show perhaps one way to get a target, at low cost. I know exactly which one of the engine i wanted, but dont see the fun in just buying, then i could bought a finished set or get someone to fix it all.
Check out this rare German 4 stroke 154ccm motor from the 20´s:
Snob 4Takt Hilfsmotor Gebaut in Düsseldorf anfang 20er J. | eBay
Old 12-16-2011, 05:43 PM
NormO's Avatar
I don't know if air movement down the road would be enough or not. I'm too much of a chicken to try it out. I'm also not going very fast most of the time either, but i can understand that you like the looks of a pure engine instead of the stupid looking plastic.
MotorBicycling.com
