Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > 4 Stroke Bicycle Engines & Kits
4 Stroke Bicycle Engines & Kits 4 stroke motorized bicycle engine kits are great if you want reliability or do not want to mix your oil and gas. Learn from each other how to get the most out of your 4 stroke bicycle engine
Old 09-19-2008, 09:41 PM
Default Titan Chain Drive Assembly And Smaller Engines
I bought a used Titan Chain Drive Assembly without engine, and it should arrive soon.
Has anyone used any engine besides the Titan with this kit? I realize this kit is pretty new, maybe no one has tried this yet. For me, the Titan and Honda 50 sit too high and might draw the local police's attention. I'm thinking of using a Mits 43cc engine, generic 47cc pocketbike engine or 40cc aircooled Polini engine. Wheel sprocket will be Staon hub with 16t freewheel. Different sets of sprockets need to be calculated and new engine mounting holes redrilled. I already had the Staton hub and if the Titan drive doesn't pan out, I have the matching Staton chain drive. I'd really like the Titan drive to work, as it seems to be an easier setup to change engines.
Any help will be appreciated.
Old 09-19-2008, 11:58 PM
Large Filipino Large Filipino is offline
Default Re: Titan Chain Drive Assembly And Smaller Engines
If you have the Titan gearbox quite a few engines out there has the same clutch/bolt pattern that the gearbox can bolt on to.
Old 09-21-2008, 04:28 PM
Yeah, the gearbox should fit the popular engines. I'm looking to retrofit the flat, compact pocketbike engines. Wheras the Titan powerplant is 10.8" length by 8.9" width by 13.94" high, the Chinese pocket is 11.75"long by 6.75" by 5" high. That means this engine is 1" longer, over 2" narrower and 9" shorter. The Polini is more compact, but 2" taller because the carb sits on top.
Maybe a 1.5L goped gas tank would work mounted on the Titan platform.
UPS dropped by with the kit on Friday but no one was home. So Monday I'll have it.
