Old 09-18-2008, 07:22 PM
phillysanchez21 phillysanchez21 is offline
Exclamation hey guys
im new here and love it. i just got my motor kit a few days ago and ready to ride but i have a few problems so will you guys please help me. i got the motor running and it sounds great but when i ride it the throttle doesn't work! When its started the motor will just run by itself without any throttle.?. i have to keep my hands on the breaks the whole time! and also when you stop the bike shouldn't the motor keep on running? mine just stops. is this part of breakin the motor in or what? Please Help!
-philly
Old 09-18-2008, 08:09 PM
Bikeguy Joe's Avatar
Default Re: hey guys
Welcome to the forum.
I think you are having a problem with the way the throttle and/or carb are set up.
The throttle should move freely with the cable hooked up, but not in the carb. Once you get that, then hook it up to the carb. Make sure the C shaped metal thing is on top of the clip, but under the spring.
Old 09-18-2008, 08:19 PM
thx for replyin i'll try that
philly loves YOU!!
Old 09-18-2008, 08:26 PM
Also, make sure you have a little freeplay in the cable housing. Screw the adjusters in at the top of the carb, and the throttle twist grip until you have about 1/16" of play.
The throttle twist grip itself can have plastic "flash" that makes operation rough too.
Old 09-18-2008, 08:35 PM
Saddletramp1200's Avatar
Saddletramp1200 Saddletramp1200 is offline
Custom MB Buiilder
Metal thing? Any extra air via a leak will cause problems for your motor. Metal Thing?
Only Bikers know why dogs love to stick their heads out of car windows,
