Old 09-17-2008, 12:18 PM
SA1JBond007 SA1JBond007 is offline
Default 80cc engine will not start...
Hello, I am new to the forum, glad i found it.
i have had my motorized bicycle for about a year...
i first installed the 80cc engine and custom exhaust and mounting for a OCC schwinn chopper bike. we had it running and traveling quite well after a few attempts. we put it away and got it out the next day, i ran it for about 45 minutes after two attempts at starting it.
the day after i had it started and was running well for 10 minutes and then it stalled out and could not ever get it started again. to this day (months later) still can not get it to start using new spark plug, proper gas mixture, etc. we know the engine is not seized, it just will not start. please, any recommendations would be a great help...
if you need anymore information from me i will do the best to provide more to you. thanks again.
Old 09-17-2008, 12:42 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: 80cc engine will not start...
Have you checked for fuel and spark?
Old 09-17-2008, 01:45 PM
OSCAR383's Avatar
OSCAR383 OSCAR383 is offline
I Would First Disconnect The Kill Switch . Many Of Those Are Bad From The Start . Try And Start Engine If It Does Not Start Pedal For A While And Pull Spark Plug And See If It Is Wet If Not You Are Not Getting Fuel . If It Is Your Nor Getting Spark . Other Things To Check Are The Fuel Filter ,if No Fuel, The Ht Tanks Come Shipped With A But Load Of Crap In Them And Can Clog The Stock Filter In The Tank . An In Line Filter Is Recommended And Also Make Sure The Connections On Your Wires Are Tight If Using Factory Wiring. . Hope This Helps
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 09-17-2008, 03:30 PM
ebmvegan's Avatar
ebmvegan ebmvegan is offline
Also check for air leaks. Good luck.
There is no moment like the now moment.
Old 09-17-2008, 03:46 PM
jasonh's Avatar
jasonh jasonh is offline
pull the spark plug and reconnect it to the wire and rest the plug on the head. pick up the bike and spin the tire with the clutch engaged. You oughta see a spark.
Old 09-17-2008, 03:53 PM
OSCAR383's Avatar
Come To Think Of It My Intake Gasket Blew After 25 Miles Of Operation. That Is Also A Good Place To Start...
Old 09-17-2008, 04:11 PM
Tj Bunch Tj Bunch is offline
Also makesure your clutch is adjusted properly......Mine had me cahsing my tail and buying a crapload of parts and cable was too tight.
Old 09-17-2008, 10:40 PM
the plug is wet when we pull it out and there is a spark when we pull it from the engine and spin tire.
what is the best way to find leaks??
is there somewhere i can purchase parts other than chasing them on ebay?? would replacing the gaskets on the whole engine make a difference at all??
what if the kill switch is bad? i hadnt tried disconnect that yet... would it go bad during operation? because it was fine for the first few days with it connected.
Old 09-18-2008, 07:37 PM
Biker Mike's Avatar
Biker Mike Biker Mike is offline
Yes, the kill switch can go bad that fast. Disconnect it and try the engine. A little moisture will cause a short in it as well. One I had lasted only 2 days and shorted out. Took me 3 days to figure it out....Grrrrrr!! Having fun now. Good luck.
Old 09-18-2008, 07:42 PM
took you three days to figure out? i will try it soon... it would be months for me before i have figured it out... lol
anyone know of a good place to find parts? or anyway to put a electric or pull start on this engine??
