Old 09-17-2008, 10:16 AM
velardejose's Avatar
velardejose velardejose is offline
Default Motorbicycling 6V electrical system?
Hi
If I hook a 6v bike batt to the white wire, could I use 6v hardware?
Like motorcycle headlights fe
Thanks in advance
Old 09-17-2008, 10:36 AM
Finfan's Avatar
Finfan Finfan is offline
Default Re: Motorbicycling 6V electrical system?
I've been pondering this idea myself and I think you will probably need a voltage regulator on the white wire to prevent overcharging and possibly a diode to keep the battery from feeding back into the magneto. Hopefully Norman will see this. He has done some work using the white wire to power a light. It might be easier to use a motorcycle battery to run a regular bicycle light system directly then just charge the battery at home periodically.
-and-
I'm not lost, I'm exploring!
Old 09-17-2008, 11:48 AM
jasonh's Avatar
jasonh jasonh is offline
I think I remember seeing a kit somewhere a while back that used a 6v battery for the lights, and the white wire would trickle charge the batt when the lights weren't in use.
Old 09-17-2008, 03:30 PM
celestmark celestmark is offline
I'm trying to find that now!!!
I want to purchase one ASAP as it's getting darker and darker here and I don't care to be buying batteries every week!
Old 09-17-2008, 03:32 PM
Dave31's Avatar
Dave31 Dave31 is offline
I've looked 4 it guys but had no luck
Old 09-17-2008, 04:01 PM
sb bikes sb bikes is offline
I use a 6v power weels battery and just recharge it. But it would be nice to know if the white wire could be used to charge it .
Old 09-18-2008, 09:33 AM
Hot Dog Piggy Tails's Avatar
Hot Dog Piggy Tails Hot Dog Piggy Tails is offline
thats 6 - 14 volts ac so first rectify it to dc with well I dont have pphoto bucket look at my icon thumbnail
Old 09-18-2008, 09:41 AM
then a regulating Ic which'el run off only your battery the package with a seperate input for its power then series its circuit inbat, the ac/dc bridge, Ic, and finally battery. and run your lights or what have you from your battery. if you get one with a regul;ator/ cuttoff it'll stop charging for you but the otherones have a range they burn your battery or theIC 9itself) up because the constant charge with no drain so check for battery temp. Some cheaper IC packages actually have an input for the battery thermistor which is axtually cheap its self. The mag white wire only gives back 3 watts so if you run your lights a 1/4 of the time and they draw 12 watts youd be ok cause the charging of the additional day use of 3/4x..Yup Im the Man. Heh Heh
Old 09-18-2008, 10:03 AM
jasonh's Avatar
Yeah, I think the search function here might need a little work....
Old 09-18-2008, 10:34 AM
Finfan's Avatar
Have you put an oscilloscope on the magneto output? I've done electronics for a while so I'm wondering what type of waveform it has.
-and-
