Old 09-13-2008, 11:20 PM
velardejose's Avatar
velardejose velardejose is offline
Default Carb assembly?
Hi
After looking at this
http://motorbicycling.com/f4/carbure...build-195.html
I looked at my carb
I found the needle's e-clip OVER the C-washer
Eclip is in the second slot from top
Bike run strong before, revving on the road till vibration
I reassembled it with the needle's eclip under the Cwasher
Seems to have less power
Bike has a 45T sprocket and a 220 lbs driver (me)
Was it properly assembled before?
Thanks in advance
Old 09-13-2008, 11:37 PM
misteright1_99's Avatar
Default Re: Carb assembly?
The c washer holds the needle and clip down in place, with the spring pushing everything down. If it ran better before you might try lowering the clip one slot on the needle (richening the air/fuel mixture) and see how it runs.
Old 09-14-2008, 07:21 AM
Bikeguy Joe's Avatar
Good advice Mright.
Old 09-14-2008, 09:39 AM
hill climber hill climber is offline
lower the clip on the needle 1 or even 2 slots the eclip is suposed to be on the bottom under the c washer . with your eclip on top that is atleast 1 notch higher in the carb than where it is suppoed to sit so when you put the needle where it is suposed to go you leaned it out. if 1 notch isnt enough and 2 is too much you can put a small washer under the eclip to raise the needle half a notch. HEY!! DO A WHEELIE! hill climber
