Go Back   Motorized Bicycle Engine Kit Forum > Bicycle Motor > 2 Stroke Bicycle Engines & Kits
2 Stroke Bicycle Engines & Kits 2 stroke engine kits need careful installation and setup, find out how from our professionals here!
Old 10-19-2011, 01:46 PM
pdn6420 pdn6420 is offline
Default Grubee Skyhawk, drive sprocket (10T) keyway too wide
Hello,
Hoping someone here can help me out. I purchased a replacement sprocket for a 66cc Skyhawk Grubee. The sprocket came with the keyway much wider than the Wooddruff key that came originally. Has anyone encountered this problem? I think the engine is a few years old. When I call the vendor they said that the shipped sprocket is the only part exist and should be interchangeable with what I have.
Can someone help me with a suggestion as to what I can do to make the new sprocket work.? the existing key is a halfmoon wooddruff key.
Thanks.
Old 06-24-2015, 08:10 AM
Jumpa's Avatar
Jumpa Jumpa is offline
Default Re: Grubee Skyhawk, drive sprocket (10T) keyway too wide
vise grip & dremel .. problem solved
Oh yea and safety goggles.
P.S. sorry it took almost 3 years for someone to reply to your question, It is very rare that you do not get 3 or 4 quick responses, by quick I mean in under an hour, I only found this because I searched out "66 CC drive gear woodruff keyway"
MotorBicycling.com
