Old 09-11-2008, 10:06 PM
luke duke luke duke is offline
Default magneto / chain sprocket cover hot hot hot
The 2 covers on the chain sprocket side of the bike are very hot! after a long ride. Iss this normal? is it anything to worry about, apart from being careful not to burn a hole in my leg when i get off!
Old 09-11-2008, 11:33 PM
azbill's Avatar
azbill azbill is offline
Default Re: magneto / chain sprocket cover hot hot hot
the engine is mostly aluminum, which transfers heats well
after a long ride, you can get branded touching anywhere
Bill
www.ezmotorbike.com
azgrampa@gmail.com
Old 09-12-2008, 07:41 AM
Bikeguy Joe's Avatar
If it's that hot, you may want to check for a lean running condition...or other source of heat.
I have ridden several hours in 80+ degree heat and while the engine/covers were hot, they were never so hot as to cause burns.
