Old 09-10-2008, 10:19 AM
bigben77 bigben77 is offline
Default New steel wheel bent!
My new wheel ran nice and true before I mounted it on my bike, now that the sproket is bolted on the wheel is out of true. can I have my local bike shop true it up with the sproket on the wheel? Yet ANOTHER reason to buy Pablo's jack shaft kit!!
Old 09-10-2008, 01:22 PM
Hitekrdnk Hitekrdnk is offline
Default Re: New steel wheel bent!
When you bolted on the sprocket it must have messed with the spoke tension. Your local bike shop should be able to get is straightened out and more than likely you will get back a much more reliable wheel than you started with to boot as a good wheel guy will tension the spokes evenly which is the key to a long lasting wheel. Along with not hitting chuck holes at speed that is.
Old 09-10-2008, 01:46 PM
OSCAR383's Avatar
OSCAR383 OSCAR383 is offline
nothing like hitting a pot hole at speed and hearing the "PING" of the rim........ make my butt pucker every time
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 09-10-2008, 02:03 PM
Dave31's Avatar
Dave31 Dave31 is offline
You might have over tightened your sprocket
Old 09-10-2008, 10:26 PM
lennyharp's Avatar
lennyharp lennyharp is offline
As a wheel builder I make sure that everything possible is done gradually and evenly. I never tighten a spoke more than a couple of half turns at a time and with tightening the sprocket I would also only tighten a few turns at a time and move around the wheel. After all is tight there could be a trueness problem and is a good reason for you to practice on a junk wheel till you are confident to true a good wheel and make it better.
LennyHarp of Lenny's Bikes & Things
http://lennyh.com
The true value of a man is not judged by what he has, but rather by what he can do without.
"We are what we repeatedly do. Excellence, then, is not an action, but a habit." -- Aristotle
Old 09-11-2008, 03:36 AM
wildemere wildemere is offline
Wheel work is easy and fun.
I build all my wheels.
The info is all here.
Building Bicycle Wheels by Sheldon Brown
