Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 09-09-2008, 01:46 PM
domdomt domdomt is offline
Exclamation Bearing troubles :(
Hi guys
Er dunno what you can suggest but, i just dismantled a chainsaw engine (no idea what make) to replace the gaskets, and took got as far as the crank housing, and all the bearings fell out on the con-rod linkage. I gathered them up, but am now stuck as to putting them back in!
Can you suggest anything?
Cheers
Old 09-09-2008, 01:56 PM
Dave31's Avatar
Dave31 Dave31 is offline
Default Re: Bearing troubles :(
Originally Posted by domdomt View Post
Hi guys
Cheers
Welcome to the forum, glad you joined us
Do not know too much about chain saw motors, but if you can find out the make and model....might be able to find a motor diagram online.
Old 09-09-2008, 01:57 PM
stude13 stude13 is offline
get a new chainsaw
Old 09-09-2008, 02:02 PM
Well, i have absolutely no idea what make it is, and no one seems to know either. It has a walbro carb, and says made in italy?
Old 09-09-2008, 02:57 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
man you have more courage than me. good luck with your project and welcome to the forum
Old 09-10-2008, 01:23 AM
CHeers and thanks for the welcome Much appreciated
Old 09-10-2008, 02:37 AM
Dave31's Avatar
I don't know about that motor? Is that metal shavings I see in the last two pics? If so.....thats a lot of shavings
Old 09-10-2008, 03:28 AM
Dave31's Avatar
I think that might be a EFCO/Olympyk motor....but not sure. You might want to take into a small engine repair shop, they should be able to help you out better.
I can see the serial # in the first pic I think
Old 09-10-2008, 11:33 AM
Yeah, one of the screws was mpossible to get at, and i realised that there was an access hole that was filled up with saw dust, but unfortunately none of my tools fitted through, so i improvised and drilled it , i'm gonna blast all the shavings off with the old compressor i think.
As for the serial number, here it is:
Old 09-10-2008, 01:53 PM
Dave31's Avatar
Well I did my best but even with serial # 4540280 I still could not find anything
