Old 09-09-2008, 06:57 AM
4wdingman's Avatar
4wdingman 4wdingman is offline
Default how does an automatic clutch motor kit work?
Old 09-09-2008, 09:52 AM
jasonh's Avatar
jasonh jasonh is offline
Default Re: how does an automatic clutch motor kit work?
The clutch is spring-loaded so when the motor hits a certain rpm, the clutch will automatically engage.
Old 09-09-2008, 10:05 AM
OSCAR383's Avatar
OSCAR383 OSCAR383 is offline
IF YOUR TALKING ABOUT A CENTRIFIGUL (MURDERED THAT) CLUTCH THERE WILL BE SPRING LOADED CLUTCH PADS INSIDE A DRUM AND ONCE ENGINE RPS ARE FAST ENOUGH TO OVERCOME THE SPRING PRESSURE THE CLUTCH PADS EXTEND TO MAKE CONTACT WITH THE DRUM AND WHEN YOU LET OFF OF THE THROTTLE THE CLUTCH PADS RETURN TO REST .
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
