Old 09-08-2008, 08:43 PM
jak stoll jak stoll is offline
Default who has used the white wire to power lights?
I got a DMM on the white wire & I dident really get a good AC or DC current from there to ground
is someone rectifying the current from there somehow?
how do you get that to work?
thanks
JAK
Old 09-08-2008, 09:20 PM
Ilikeabikea's Avatar
Default Re: who has used the white wire to power lights?
I've got 2 of Normans lights that work off the white wire and they work great. Just hook em up and they work...................
Old 09-08-2008, 09:38 PM
what Im doing now is carying two 4 cell A123 bats 2300mah each & with the two of them I can get about 1.5 hours out of a 55 watt H3 bulb with a bright marker as a tailight
I like my current setup
but was just curious about using the white wire
take care
JAK
Old 09-08-2008, 09:43 PM
Dave31's Avatar
Dave31 Dave31 is offline
http://motorbicycling.com/f23/lights...-work-236.html
Old 09-19-2008, 01:04 PM
Doug Doug is offline
I use the white wire on my Dax 70 to power a tail light. I have a red accessory light (I forget the specs), which I think is meant for a trailer, that I bought at Autozone. I ran the wire for it through a switch on the side of my rack.
I have let the engine warm up and smooth out at night and then turned it on. Works fine. No special kit.
Old 09-20-2008, 08:23 AM
HT60CC HT60CC is offline
I'm hoping to use the white wire to power lights. I'll post back with more info soon.
Theres more to life than MPG
Old 09-20-2008, 10:09 AM
velardejose's Avatar
velardejose velardejose is offline
Hi
I would like to buy the lights offered here
But s/h costs would kill me, so I must look for options
Jose
Old 09-20-2008, 10:34 AM
saetta's Avatar
saetta saetta is offline
I am using the white wire to power my headlight with good results! My headlight is from a 70s bicycle generator system.
Old 09-26-2008, 01:33 PM
FileStyle's Avatar
have a bike and using same set up as saetta but I also using a tailight works great! had problems with my other bike though couldnt get my lights on after warm up without killing the engine ! come to find out bad spark plug wire , replaced and good to go!
FileStyleCycles
Old 10-05-2008, 06:45 AM
SgtNorthcutt's Avatar
SgtNorthcutt SgtNorthcutt is offline
Default 6 Volt LED headlamp w/ small 6 volt motorcycle battery
I am working on a 6 volt LED headlamp and the guy at the autoparts place told me to use a small 6 volt motorcycle battery and run the white wire to it, then run a wire from the battery to the headlamp so the motor would not be using the spark juice to power the light. Any thoughts on this?
Motorized Bike Builder
Veterans Advocate
Sgt/USMC (fmr)
OIF 2.2 Combat Injured-Veteran
Black Death
PK-80 Powerking Limited motor, 26" single-speed Schwinn Del Mar with rear coaster brakes only (not recommended)
Top Speed: Unknown
PK-80 Powerking Limited motor, 26" 7-Speed Schwinn "Point Beach" Cruiser
Top Speed: 34
