Old 09-08-2008, 02:12 PM
bigben77 bigben77 is offline
Question Coaster Break noise?
I just converted my Schwinn Jaguar seven speed wheel to a steel coaster break one speed. My concern is the strange clicking/grinding noise coming from the sprocket on the bicycle side. I took the wheel off to adjust, I loosened the tension on the nuts next to the cones and the noise is gone and wheel spins nice and smooth. I reinstal wheel and and noise and grinding return! Are my nuts too tight? Is my new wheel defective? I have not ridden a coaster break bike in 25 years, is this normal?
Old 09-08-2008, 02:28 PM
OSCAR383's Avatar
OSCAR383 OSCAR383 is offline
Default Re: Coaster Break noise?
are you using a cone wrech to hold cone nut when you tighten to keep excess pressure off the bearing if not they will grown and grind???? and do the bearing need some grease???
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 09-08-2008, 02:30 PM
No, I don't have a cone wrench. Are they expensive?
Old 09-08-2008, 02:37 PM
OSCAR383's Avatar
not usually you local bike store should have them. you can even take an old wrench and file it down so that it fits on the skinny flat edges of the cone nut while you tigten the nut on the outside. so you dont compress the bearings in the hub or a skinny pair of needle nose pliers
Old 09-08-2008, 07:32 PM
Dave31's Avatar
Dave31 Dave31 is offline
Yes, it sounds like you are running your bearings too tight.
Like Oscar says be sure you have greased them good. And I do not own a cone wrench, I did what Oscar suggested and took some old wrenches to the bench grinder.
Spooky Tooth Cycles - Motorized Bicycles: Gas Powered and Electric Bikes - Video how to: Coaster Brake Hub Overhaul
