Old 09-08-2008, 07:51 AM
MrLarkins's Avatar
MrLarkins MrLarkins is offline
HS Math Teacher
Question HT "80cc" Horsepower?
How much horsepower does the HT "80cc" actually have? I'm just curious.
Old 09-08-2008, 08:19 AM
Dan's Avatar
Dan Dan is online now
Default Re: HT "80cc" Horsepower?
I always assumed around 2, but dunno for sure.
I want 2 ride my bicycle
Old 09-08-2008, 10:24 AM
Jemma Hawtrey's Avatar
Jemma Hawtrey Jemma Hawtrey is offline
a figure I saw bandied about was 2.2hp - but to be honest the quality is so variable on some of them it could be anything - although I think 5 hp would be pushing it.
There have been 50cc engines with upwards of 6hp - I'd love to make a frame mount with the fantic engine and 6 speed transmission - that would fly..
Jemma xx
"....Look, no pedals... *thud*..." The mating call of the motorized-biker.
"RetroEagle" - 32cc Two-Stroke, Piped. 35mph on #13 gear. Reversed stem with springer fork.
Old 09-08-2008, 03:56 PM
Revorunner's Avatar
Revorunner Revorunner is offline
Jemma xx
Hi,
I'm new to the fourm,just curious about the six speed transmission you mentioned.Do you have any pics of it or a website that I can get more info of it?
Old 09-08-2008, 04:25 PM
jasonh's Avatar
jasonh jasonh is offline
I think the Morini 50cc motor even comes in a 12hp version
As for the transmission, I'm not familiar with the one Jemma mentioned. However, SickBikeParts sells a kit to use the gears on your bike to drive the motor. See their ad on the left.
Old 09-08-2008, 07:34 PM
jf30cp's Avatar
jf30cp jf30cp is offline
has 2-3 horsepower....but if you do mods it can go up....although, the motor will only handle 6 horspower max before things start getting broken within the motor
Big Boss Hoss
My "happy time" engine is so damn happy I heard it giggle at me today
Old 09-09-2008, 01:50 PM
Revorunner's Avatar
Thanks for the info.
Old 09-09-2008, 01:54 PM
Dave31's Avatar
Dave31 Dave31 is offline
Hello Revorunner, Welcome to the forum, glad you joined us
Old 09-09-2008, 02:03 PM
Revorunner's Avatar
Thanks,
I have been lurking around this fourm for awhile now doing research on building a motorized bike.
Still undecided on what motor to get though.Leaning towards the Honda 50cc.
Old 09-09-2008, 03:44 PM
Originally Posted by Revorunner View Post
Hi,
Its not a separate transmission as such. The Fantic TI sportmoped had a completely deranged motor coupled to a 6 speed tranmission in the casing ala the standard motorcycle practice.
However.... this could be made, or at least something similiar could be. The shifter kit that pablo does is a great idea, but all the cassettes for derailliers are for cycling speeds... so you might get several ratios but you are limited to the available ratios that are fairly shallow for a motor vehicle because they are designed for pedalling.
To get a fantic-esque type of performance you would need to make up a cluster that has ratios more suited to an engine application than a pedalled one. A good trick would be a low first and second ratio (in case of emergency cycling) and then a gap to higher ratios that are more motor friendly.
However as compared with the CIF engines the Fantic mill was impressive to say the least. Below 50ccs displacement - 12:1 compression ratio (the CIF are something along the lines of 7:1) and either a 14mm dellorto carb (6.5hp) or a 19mm carb running the motor up to 7.2hp.
The only engine that comes close really is the morini engine that some have used on here and that so far as I know doesnt have an integral transmission.
hope that helped
Jemma xx
