Go Back   Motorized Bicycle: Engine Kit Forum > Bicycle Motor > DIY Home Built Motorized Bicycle (non kit)
DIY Home Built Motorized Bicycle (non kit) Post all about your home built rides here. Weedwacker motors, lawn mower engines ect. This area is for non kit builds
Old 09-07-2008, 09:56 AM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
Default what it is bro?
Okay quick background. I bought this engine on ebay and it didn't run just right. I tried to adjust the carb and it didn't do any better so I put on a new carb I had laying around. I do mean new not just an old one that was new to the engine.
Does the same thing. I put a hole in the muffler just in case it needed a better vent. Same thing.
I can get it to start no sweat. It will rev up... Sometimes it will take off and run great. Then for no real reason it will bog down. Sometimes I can let off the throttle a little and it will take off again and not do it for a while. Then when I throttle up later it will bog down. I let off and sometimes it will take off again and sometimes it will just keep dragging along. Two minutes later I varry the throttle and it takes off again.
I would think it was something I did except that it did it with both carbs. Maybe it's a leaky manifold gasket. I need to see if the manifold gasket is there cause come to think of it, I might have seen a piece of gasket laying on the ground outside the shop. I have torn apart so many engines it might have nothing to do with it though.
So what it is bro.
Old 09-07-2008, 10:06 AM
deacon's Avatar
Default Re: what it is bro?
I wonder if it could be as simple as a clogged fuel filter. I did reuse the old one when I changed the gas tank. If that was the original problem it would still be the problem.
Old 09-07-2008, 10:10 AM
Large Filipino Large Filipino is offline
It could also be your gas cap not letting enough air in. That's an easy check. Try running it with the cap off.
Old 09-07-2008, 10:52 AM
comfortableshoes comfortableshoes is offline
Talking Re: what it is bro?
ON the side of the Ryobi 790r there is a allen head bolt- black and different from all the other bolts on the damn thing- Mine was loose and had a lot of the same issues your describing, when it got really loose my engine would start up, race and then die.
One I figured out the issue I tightened that down and man she's been sweet to me ever since.
On the gas cap issue- do you have the original ryobi cap? he stock cap is black and yellow, tightened down there is a really nice venting system that works well.
Did you check your: fuel lines, bulb etc? I've read alot on here about those being the source of some major issues with the weedwackers.
Made in china, made better in my garage
Comfortable Shoes Studio Tool Rolls and Pouches
MyMotoredBike.com
Flicker Page
Don't feed the trolls!
Old 09-07-2008, 11:52 AM
deacon's Avatar
I have my own gas tank with vented cap, but I will check cause it might well be the issue.
