Old 09-05-2008, 11:07 PM
shiloh0 shiloh0 is offline
Default kit fuel line
ok, what's up with the "fuel line" they give you with these motor kits? every time i put one together i come to the fuel line and then with shaking hands
i bend it, examine the thickness, smell it , etc. then i think, well maybe they fixed it and i put it on. the gas seeps down the carb and drips from the float bowl. or it doesn't until you touch the line slightly then it starts leaking.
i keep thinking maybe just once they could (at the chinese motor factory) send a guy out back to put the thing together and report on it. so they could fix any defects. maybe they do this already and leaking gas is not considered a defect in china. or maybe thats all they can find for fuel line.
im not a sino-phobiac by any means, but it's just frustrating that little, but important issues can't be corrected.
"You must cultivate the feeling that a warrior needs nothing"-don juan
Old 09-06-2008, 08:02 AM
GoFastBicycles's Avatar
GoFastBicycles GoFastBicycles is offline
Default Re: kit fuel line
I had the same probs. Use small wire ties as clamps works like a charm.
Old 09-06-2008, 08:33 AM
Bikeguy Joe's Avatar
Buy some real 3/16" gas line and secure with zip ties, wire, or small spring hose clamps.
Old 09-06-2008, 09:18 AM
Pablo's Avatar
Pablo Pablo is offline
Just use the supplied tube up for the filter to carb link (Use 1/4" valve to filter). But change that garbage once a month or so - then find some 3/16" line. Mine never leaked but it shrinks and gets brittle. I use zip ties. They are cheap, small and do a great job. No leaks!
Old 09-06-2008, 01:03 PM
Saddletramp1200's Avatar
Saddletramp1200 Saddletramp1200 is offline
Custom MB Buiilder
The higher end auto parts stores have stainless braided fuel line by the foot. They are NOT cheap, but rocket fuel won't hurt them. Clamps are about a buck each. about 10.00 usd.
Only Bikers know why dogs love to stick their heads out of car windows,
Old 09-06-2008, 03:18 PM
deacon's Avatar
deacon deacon is offline
minor bike philosopher
I have black fuel line from the auto parts store seems to work at least it doesn't get brittle and break in the cold.
Old 09-10-2008, 09:34 AM
HoughMade's Avatar
HoughMade HoughMade is offline
That's what I use...and personally, I think the clear/yellowish fuel line looks cheap- but to each their own. I would never run a fuel line without a proper spring clamp, spring-wire clamp or worm-drive band clamp at each connection. Those things were not invented for no reason.
29/10ths cubic inches of raw power.
HoughMade at WIRED.com: http://www.wired.com/cars/coolwheels...memade_bicycle
Old 09-18-2008, 01:19 PM
2door's Avatar
2door 2door is offline
Something to keep in mind when buying fuel hose from an auto parts store. Because of the new alcohol blend fuels you should always opt for the high priced fuel line as opposed to the older/cheaper, neoprene type. I got an emergency e-mail from my auto insurance company regarding this issue a year ago and shortly after experienced a fuel leak on my hot rod. The old fuel line had deteriorated due to its incompatibility with the alcohol fuels we have here in Colorado. Like the man says, "It ain't cheap." but what's a couple of dollars compared with the price to replace your bike/hot rod/boat etc. if it burns?
Old 09-18-2008, 04:30 PM
jasonh's Avatar
jasonh jasonh is offline
Pretty soon it's gonna go from "Big Oil" to "Big Corn"
Old 09-18-2008, 04:36 PM
Pablo's Avatar
Is that like cornholio?
