Old 09-05-2008, 03:11 AM
fume555's Avatar
fume555 fume555 is offline
Cool Mpg is waayyy low
I'm running full tank 20:1 still on my first gallon and after riding about 30 miles I'm already at half tank. This must mean I'm averaging 60mpg which is half of what kit said (150). Is it because of the oil mix ratio that causes it to burn up so fast? Is it normal to kill your engine by choking it all the way and is it normal if the engine itself smokes(not exhaust smoke)?
Old 09-05-2008, 07:22 AM
Pablo's Avatar
Pablo Pablo is offline
Default Re: Mpg is waayyy low
I doubt 150 mpg, but 60 mpg does sound like you are leaking or sucking raw fuel.
Expect maybe about 80 mpg on a bolt on sprocket HT engine set-up.
I would start reading on tuning.
New plug and wire.
Needle on lean slot.
Smaller carb jet.
Look for carb leaks, defects.
Old 09-05-2008, 08:24 AM
Ilikeabikea's Avatar
So do you have a 1 gallon tank? Most of them I've seen are just 1/2 gallon tanks..............................
Old 09-05-2008, 08:32 AM
Pablo's Avatar
Interesting perspective!
Old 09-05-2008, 09:23 AM
jasonh's Avatar
jasonh jasonh is offline
what he said
Old 09-05-2008, 09:27 AM
OSCAR383's Avatar
OSCAR383 OSCAR383 is offline
if you only have a half gallon tank youd be at about 120 mpg about what i get and that aint bad.
MEASURE ONCE AND CUT TWICE.......WAIT A MINUTE
Old 09-05-2008, 12:51 PM
fume555's Avatar
Whoops, I mean I got a half gallon tank Does that mean I'm getting 60mpg
Old 09-05-2008, 01:02 PM
That means your getting 120 mpg..................
Old 09-05-2008, 02:22 PM
Bikeguy Joe's Avatar
New engines use more fuel, so do ones that are running too rich.
Old 09-05-2008, 03:24 PM
fume555's Avatar
How many gallons/miles does it take to fully break my engine in? My top speed as of right now is about 30 mph. How much increase will there be once my 80cc is broken in?
