Old 04-02-2011, 03:18 AM
The_Aleman's Avatar
The_Aleman The_Aleman is offline
Default Re: Need help installing throttle
Try this diagram posted by 2door, don't use white wire for kill switch. The original kit directions say to use white wire, and some members here still hook up switch that way, but I've personally fried 2 magnetos and a CDI using white wire. Sure I can't prove it was white wire itself that did it, but I never fried either after capping white wire off completely.
File Type: jpg 8342d1242066058-kill-switch-wiring-electrical-diagram.jpg (48.5 KB, 40 views)
Old 04-02-2011, 05:29 AM
DaveC's Avatar
DaveC DaveC is offline
Originally Posted by rohmell View Post
The white wire from the engine is an output, and is normally used to run a light.
The black is ground and the blue is the output from the magneto.
The kill switch should be connected to the black and blue wires, the white wire should be taped up and tucked away if you are not using a light.
Attachment 34859
This is exactly how to hook the killswitch up. Yes, hooking it up to a ground does work but there are some setups that isolate the engine so well that the point of contact is the cables, not a good ground. I ran a wire from the chain guard mount on the motor to one of the water bottle holder bolts. Then whatever grounds for electronics hook up there but I still have the killswitch connected to the two magneto wires.
